Home > Technical > Pdc fuse
firstinretail
United Kingdom 2005 Range Rover Sport 4.4 V8 Siberian Silver
Pdc fuse
Range rover sport 06 petrol s/c with faulty PDC
Have pulled out fuse 36 but that causes the car to go mad, transmission faults etc.
I am sure this is the right fuse, anyone know.
My sensors are doing the long beep,and deactivating, just wanted to chech the fuse first, I would however would have though if the fuse went it would not be beeping at all???
I have tested for clicks and none of the sensors click.
This car is killing me:
Last 3 weeks list of repair.
2 wishbones
Rear and front anti roll bar bushes
All the belt tensioners
Wheel bearing
New drivers door lock after it failed in dead lock mode.......had to smash the lock via a gap in the window trim.
Full transmission service
Full service
Mot
�2500.....
The day it came back, the bloody parking sensors packed in. If you took some fog and put it in a jar, would it be missed.
Post #386610 Fri Jun 21 2013 10:47pm
firstinretail
Just realised this is in the wrong section sorry If you took some fog and put it in a jar, would it be missed.
Post #386620 Sat Jun 22 2013 8:15am
firstinretail
Ok, update, it is fuse 36 the numbers are at the top of the fuse not the bottom...... Duh!
And who on gods earth form landrover decided that was the best place for a fuse box, pretty much the dumbest place you could find, certainly the tightest fuse box I have ever had the misfortune to get to.
Anyways, problems with pdc has nowt to do with the fuse, if the fuse goes, it all stops working, no errors or beeps.
So it must be a sensor, have ordered one for �18 and will remove the front bumper and start swapping when it arrives. If you took some fog and put it in a jar, would it be missed.
Post #386661 Sat Jun 22 2013 3:12pm
firstinretail
update:
one sensor was faulty in the front bumper: (�18 of flebay)
the front bumper is easy to get off but my findings are as follows.
the torx screw under the car either snaps off or round, I only got one out, self tappers fix it back on.
If you can get away without removing the washer hose from the headlight washers then fine, as the pipe to the T piece are sooooooo tight, also the T piece breaks really easy. If you took some fog and put it in a jar, would it be missed.
Post #387146 Thu Jun 27 2013 9:14am
PEACHY
Bow down WELL DONE Bow down now have a refreshing cup of tea - seriously don`t you think these cars are Censored when things go Censored up. Thumbs Up 16MY Estoril Blue SVR.............
Post #387149 Thu Jun 27 2013 9:45am
firstinretail
Oh yes, however just finished cleaning it and it,looks mint..... Not sure what will fall of next but when they are clean and working there's nowt better.
Oh I forgot, when I was climbing in through the passenger side because of the door lock, I found the side step was rotten, so that was another �150 If you took some fog and put it in a jar, would it be missed.
Post #387381 Sat Jun 29 2013 5:23pm
