![]() | Home > General > Clarkson writes . . . |
Yep, your provider probably fronts the license fee so they can rebroadcast BBC. As VA says, it's worth having... especially as there are now countless BBC digital channels covering all sorts of subject matter.
Plus various previous episodes on daytime. 2005 Zambezi TDV6 - Gone but not forgotten
Worth seeing if you can get the UKTV channels too. UKTV is mostly owned by the BBC and they use it as a vehicle to repeat all the classic stuff. |
DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045 ![]() ![]() |
Angel, do you have a steerable dish? If so you could point to the Astra sats that Sky uses (28degEast from memory). Alternatively have a 2nd dish. Get a cheap Sky digibox from Fleabay (see http://cgi.ebay.co.uk/Pace-DigiBox-Sky-Sat...otohosting as example), then get a free to air card. "free to air" cards are free to UK addresses so I'm sure someone could send you out one. Alternatively if someone has disconnected Sky TV in the UK, the card still allows BBC etc free.
Derek you actually sound geeky! |
Here you go, this gives you all the gory details by the looks of it:
XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894 ![]() ![]() |
Thanks La shmoogle |
That's what I was trying to say, they just put it better! Channel is BBC2. |
