Home > In Car Electronics > Bluetooth dead |
Firstly, welcome
Wed Jun 05 2013 8:41am |
do you get sound normally on the stereo? which means the BT unit is powered and MOST circuit is complete.
Wed Jun 05 2013 9:28am |
Guern sport Member Since: 04 Jun 2013 Location: Guernsey Posts: 7 |
Hi Bodsy, thanks for your help. Everything else works fine (stereo etc) and yes i have all of the phone controls on the steering wheel. When i have tried all of the phones, they do not see the car at all. I did buy the car on Monday from a garage on behalf of a private seller, but i have since found out that it has an extaended warrenty with the local main stealer. I will therefore be going through the car with a fine toothcomb to find anything else that needs doing! |
Wed Jun 05 2013 9:48am |
Wed Jun 05 2013 9:52am |
Thanks. I will try unplugging and re seating tonight. If i do need a new one and i do as you suggest and buy a D4 unit, i take it that apart from a loom / plug mod it will just work and that wont be any programming issues?
Wed Jun 05 2013 12:35pm |
yes, the only thing you need is a two pin cable, available from Maplins
Wed Jun 05 2013 12:46pm |
I checked it. I accessed the hidden screen and looked in the configuration folder. It listed Bluetooth was there. The other thought that i had is that it may be a CCF issue, ie has the radio head unit been changed or something and the car hasnt been configured properly. I have spoken to the previous owner, and they never used the phone facility so it may never have worked from day 1 |
Wed Jun 05 2013 2:35pm |
if you want to send the module to me, I'd be happy to check it out for the cost of postage, just to eliminate that as either the cause or not of the problem.
Wed Jun 05 2013 2:37pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Just as a side bar, my Fullfat module went down and everything else worked. The cigar lighter in rear had been fed a 5p and blown the fuse. Check your sockets are working and that fuse which on mine was linked to Bluetooth unit is ok. Possibly a red herring as Fullfat unit is behind dash where as sport is in side panel of boot. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Sat Jun 29 2013 7:55am |
