Home > In Car Electronics > Bluetooth dead
Guern sport
2008 Range Rover Sport TDV6 HSE Stornoway Grey
Bluetooth dead
Morning all. First post here. Just purchased a 2008 RR sport HSE. Very pleased with it however the bluetooth is totally dead. It wont pair with any phone (3 tried). It is phisically there (in the boot) and appears in the dealer screen as having bluetooth fitted. I have also carried out a hard reset. Crying or Very sad
Any ideas anyone
Post #384703 Wed Jun 05 2013 7:58am
Firstly, welcome Smile
Worth contacting member 'Bodsy' on here, he is the guru for all thing bluetooth (and other electronic issues) and I'm sure he'll pop along in a bit Thumbs Up ON THE WAY: BMW F21 M140i
Post #384707 Wed Jun 05 2013 8:41am
Bodsy
Site Sponsor
do you get sound normally on the stereo? which means the BT unit is powered and MOST circuit is complete.
When you search for devices, does anything come up at all? what code do you use to try pairing (if anything comes up) I assume you have the red/green phone buttons on the right hand side of the steering wheel.
I have some updated software BT modules here ready for swap out, but if your unit is faulty, then you need to get a new one. £200 + postage (I obviously don't want a faulty module!)
Did you get the car from the dealer? If so, then they should fix. If they have to buy a new module, ask them to buy a Discovery 4 module as it has much better functionality and just needs a couple of wires from the d3 connector onto the d4 unit. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #384709 Wed Jun 05 2013 9:28am
Guern sport
Hi Bodsy, thanks for your help. Everything else works fine (stereo etc) and yes i have all of the phone controls on the steering wheel. When i have tried all of the phones, they do not see the car at all. I did buy the car on Monday from a garage on behalf of a private seller, but i have since found out that it has an extaended warrenty with the local main stealer. I will therefore be going through the car with a fine toothcomb to find anything else that needs doing!
Post #384713 Wed Jun 05 2013 9:48am
Bodsy
Site Sponsor
have you tried disconnecting the module and plugging it back in. I have found a couple of peopple who didnt seat the module all the way home, so had intermittent connections or just not working properly. Thumbs Up Bodsys Brake Bible
See it HERE
Post #384714 Wed Jun 05 2013 9:52am
Guern sport
Thanks. I will try unplugging and re seating tonight. If i do need a new one and i do as you suggest and buy a D4 unit, i take it that apart from a loom / plug mod it will just work and that wont be any programming issues?
Went to the main stealer at lunchtime, and guess what - telephony etc is not included in the warrenty!
Post #384725 Wed Jun 05 2013 12:35pm
Bodsy
Site Sponsor
yes, the only thing you need is a two pin cable, available from Maplins
The D4 module is a different shape to the D3 module, so you may need to use a couple of cable ties to keep it in place, but thats the only thing that is needed as long as there is no other issue with the car configuration, but you are saying the dealer has checked this? Bodsys Brake Bible
See it HERE
Post #384726 Wed Jun 05 2013 12:46pm
Guern sport
I checked it. I accessed the hidden screen and looked in the configuration folder. It listed Bluetooth was there. The other thought that i had is that it may be a CCF issue, ie has the radio head unit been changed or something and the car hasnt been configured properly. I have spoken to the previous owner, and they never used the phone facility so it may never have worked from day 1
Post #384734 Wed Jun 05 2013 2:35pm
Bodsy
Site Sponsor
if you want to send the module to me, I'd be happy to check it out for the cost of postage, just to eliminate that as either the cause or not of the problem. Thumbs Up
Unless you know someone else local that is able to test it? Thumbs Up Bodsys Brake Bible
See it HERE
Post #384735 Wed Jun 05 2013 2:37pm
simple1
Just as a side bar, my Fullfat module went down and everything else worked. The cigar lighter in rear had been fed a 5p and blown the fuse. Check your sockets are working and that fuse which on mine was linked to Bluetooth unit is ok. Possibly a red herring as Fullfat unit is behind dash where as sport is in side panel of boot. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #387353 Sat Jun 29 2013 7:55am
