Home > Technical > Radio Low Power Mode And Car Not Starting>??
napsterboy70
Hi guys,
the past few times i have been in my RRS i put the key in to start the engine, first two clicks of the key are fine, dash board works, radio comes on etc, but on the third click to actually start the engine there is nothing there, not starting, just a faint clicking sound, any idea of what this could be please?? also when the car has started, the radio is saying LOW POWER MODE and will not let me turn it to above 20 or something?? could this be related?? any suggestions or previous experience of this will be a massive help.
Thanks
Post #384518 Sun Jun 02 2013 9:09pm
Bodsy
Site Sponsor
All related, you just have a flat battery. Charge it up and you'll be fine, unless the alternator has gone. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #384519 Sun Jun 02 2013 9:25pm
mrfixit
2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Battery and definatley the alternator,get it started and stick a meter on the battery,it should read 14V +.but going off what you say it's knackered.
Post #384521 Sun Jun 02 2013 9:26pm
napsterboy70
thanks for the quick reply guys, will check the battery in the morning, if the alternator has gone or is on its way out is there any test i can do on this to check?? also wheres best place to get an alternator??
thanks
Post #384522 Sun Jun 02 2013 9:31pm
Advanced Factors
Site Sponsor
If you should need one....
http://www.advancedfactors.co.uk/electrica...t-27-c.asp Paul Redding
+44 (0)23 8052 2776
paul@advancedfactors.co.uk
Post #384524 Sun Jun 02 2013 9:38pm
