Home > Wheels & Tyres > What size spare?? 22" wheels
Mattyp1
2007 Range Rover Sport TDV6 HSE Java Black
Hi , my spare has been stolen, I'm unsure of what size tyre to get? Currently car has 295/30/22 on, my friend is selling a 255/55/19 spare.... My question is if I have to use the spare in emergency, would I have suspension problems, warning lights etc? Or would it be ok to use for a very short while?
Would be grateful if anyone could advise on best spare tyre size for 22's? As obviously can't get a 22 in the spare wheel well.
Thanks in advance for any help guys
Post #383524 Sun May 19 2013 6:06pm
GazP
United Kingdom 2006 Range Rover Sport Supercharged Adriatic Blue
By my calculation your mates spare would be 1 inch smaller across the diameter. Although this isn't ideal in theory it's only a tiny bit different to what LR have as standard when the car comes with 20 inch wheels. This is because the spare your mate has is what LR use. I think though...... The closer you can get to the same diameter the better. You are right about suspension adjustment but also the diff as the spare will spin at a different speed.
Post #383525 Sun May 19 2013 6:24pm
Mattyp1
Thanks for reply gaz
Would you say a no to that wheel then? What tyre size would anyone recommend if not? Just know if I don't sort it soon.. The inevitable will happen.. Sod's law!
Post #383526 Sun May 19 2013 6:33pm
GazP
I do have that wheel size for my spare, although i have 20" wheels. This difference is probably less than 5mm from my combo. I'm not sure what to advise mate. Maybe some of the guys with 22" wheels could comment on what they use?
Post #383529 Sun May 19 2013 7:20pm
