![]() | Home > Wheels & Tyres > What size spare?? 22" wheels |
GazP Member Since: 06 Apr 2013 Location: Stevenage Posts: 29 ![]() ![]() ![]() |
By my calculation your mates spare would be 1 inch smaller across the diameter. Although this isn't ideal in theory it's only a tiny bit different to what LR have as standard when the car comes with 20 inch wheels. This is because the spare your mate has is what LR use. I think though...... The closer you can get to the same diameter the better. You are right about suspension adjustment but also the diff as the spare will spin at a different speed. |
Mattyp1 Member Since: 03 Oct 2012 Location: London Posts: 10 ![]() ![]() |
Thanks for reply gaz
I do have that wheel size for my spare, although i have 20" wheels. This difference is probably less than 5mm from my combo. I'm not sure what to advise mate. Maybe some of the guys with 22" wheels could comment on what they use? |
