![]() | Home > For Sale & Wanted > genuine range rover sport side steps / running boards wanted |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 ![]() ![]() ![]() |
thanks Ady 555 ! Looks like i've come to THE forum for RR owners |
started installing them yesterday, purchased via Super Tweaks.
also, the following pdf was useful, especially when cutting the sills (you gotta log in/register to be able to download it):
You should have gone for 'pre-cut' sills |
RWA5H Member Since: 22 Mar 2013 Location: Kent Posts: 87 ![]() ![]() |
Well done for tackling the "no cills" version. Better man than me, hats off to you mate.
I have a new set of uncut sills if anyone wants them to practice on. |
i was tinkering with the idea of precut sills, but in fact following the guide on the pdf the procedure was very simple !
Robfellows Member Since: 02 May 2013 Location: Wolverhampton Posts: 10 ![]() ![]() |
Have a look at LR parts in Liverpool, £150 plus vat with cut out and they state with rubber non skip not plastic, it looks like they also fit.
rabcnesbit Member Since: 29 Jun 2010 Location: London Posts: 95 ![]() ![]() |
What's the difference between the ones with the side sills and the ones without (i.e. what are these side sills; is it easy to cut out or is it not worth the hassle?) . Thanks |
The side sills are the plastic parts that cover the bottom side edges of the car, you can see them when you open the doors.
Thanks. ![]() So, is it necessary to cut them out? I mean why sell them with these not cut out out already if it is something that's not required / meant to be cut out? |
Oh yes its necessary to cut them out or they wont sit properly with the new brackets in place. I wanted to keep the original sills in place which is why I opted to cut them, but it seems most people go for the precuts. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Thanks. ![]() |
