![]() | Home > Tips & Tricks > Changing a tyre |
Lateral5 Member Since: 07 Jun 2006 Location: Down south Posts: 331 ![]() ![]() |
Got a screw through my tyre last night (see gallery), which was notable for a few reason;
Too right! I'd always cut my losses and get LRA on the phone as soon as you know you have a flat. Don't want to ruin your Armani threads having to deal with tools! |
XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894 ![]() ![]() |
hahaha |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 ![]() ![]() ![]() |
MDP Member Since: 15 Jun 2005 Location: Back in an AUDI Posts: 8598 ![]() ![]() |
I had to change a wheel/tyre last year |
Doesn't the space saver look odd next to the 20... |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
you know .... I quite like it.... how do you think it'd look with 4 on ...... Hmmmm |
Space saver looks really wierd on the RRS brutus....talk about taking off the work boots and putting on high heels!! Nice lawn MDP!
Yeah its impossible to get the 20" underneath - so LR fit this cheap affair that limits the Supercharged to a maximum 50mph - considering you could be miles from home and over holidays or weekends thus no way of locating a replacement tyre. [ i have connections in the trade & they couldn't locate one straight away ] it took my dealer 24hrs to get hold of one as well |
Bobs_buggy Member Since: 30 Apr 2006 Location: Pump No.3, usually! Posts: 213 ![]() ![]() ![]() |
I've got a full sized 20inch spare on mine. It's strange that the 19inch "spacesaver" only weighs a couple of pounds less than the 20inch (5st 6lb), even though it's alloy. The 20inch wheel fits a treat, but you can't put a punctured one under there because it's supposed to sit on the inflated tyre walls. RRS 4.2 S/C. Zermatt. Tints. Stormers. 150+ paint defects, wonkey bonnet, scratches, detached doorseal. suspension faults. To sum it up, a �60k pile of cr4p! |
Hhhhhmmm - Ok,
Zipperman19 Member Since: 22 Aug 2005 Location: South Florida Posts: 85 ![]() ![]() ![]() |
The doesnt seem to make much sense because with the 19 you have to put the flat in the trunk. It cant possibly be to cut costs. Maybe to bring it close to a 50/50 weight distribution or so the wheels is not too heavy for someone to remove from underneath? |
..............but there's only a few pounds difference in weight. That would easily be offset by putting a bag of shopping in the boot (or the driver loosing a few pounds)!
