![]() | Home > Technical > Water in Fuel 2007 tdv8 |
Markos Member Since: 09 Dec 2007 Location: Ljubljana Posts: 187 ![]() ![]() ![]() |
If I remember Fuel filter is located under plastic cover front middle part of the car little more to the passenger side. When you are chaning the filter watch out that you do not brake the sensor (plastic thing which is If I still remember screwed in the filter) - A service guy told me that it can brake easy 2008 RRS TDV8 HSE, Java black, Alpaca,..... |
Don't jump in just yet, mine does it after fording and it's just a sensor issue and not actually water in the fuel.
Here you go;
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4442 ![]() ![]() ![]() |
Either drain the filter, or get a new filter, and don't replace the sensor. Comes with a plastic plug in the bottom without a sensor |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
Or just ignore it in the hope that the message never reappears like mine |
austencameron Member Since: 11 Apr 2012 Location: Fife Posts: 41 ![]() ![]() ![]() |
thankyou all for the help, located near the driver side under transmition cover, new fuel filter fitted. |
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 ![]() ![]() ![]() |
I changed mine and now the bloody water in fuel light comes on and I didn't re fit my sensor lol |
mjbrr Member Since: 31 May 2012 Location: Durham Posts: 81 ![]() ![]() ![]() |
I get this about every 6 months or so and just clears by itself |
