Home > Technical > Water in Fuel 2007 tdv8
austencameron
hello
water in fuel came on this morning so i am going to change the filter and have a look at the sensor.
before i start taking covers off , does anyone know the location on the car?
thanks
Post #377780 Fri Mar 22 2013 7:59am
Markos
Slovenia 2008 Range Rover Sport TDV8 HSE Java Black
If I remember Fuel filter is located under plastic cover front middle part of the car little more to the passenger side. When you are chaning the filter watch out that you do not brake the sensor (plastic thing which is If I still remember screwed in the filter) - A service guy told me that it can brake easy 2008 RRS TDV8 HSE, Java black, Alpaca,.....
Post #377798 Fri Mar 22 2013 10:24am
Don't jump in just yet, mine does it after fording and it's just a sensor issue and not actually water in the fuel.
Have you been thorugh water/deep puddles recently? RRS gone
Post #377807 Fri Mar 22 2013 11:45am
Paddi
Here you go;
http://www.rrsport.co.uk/forum/topic27895....uel+filter 2008 MY Java Black TDV8 HSE
Post #377808 Fri Mar 22 2013 11:45am
Disco_Mikey
Either drain the filter, or get a new filter, and don't replace the sensor. Comes with a plastic plug in the bottom without a sensor Thumbs Up
If that does not cure it, it will need a new filter housing. Around �65 or so, a genuine filter costs around �45. May be worth just biting the bullet and replace the housing if draining it does not work
Post #377809 Fri Mar 22 2013 11:59am
Bradders
Or just ignore it in the hope that the message never reappears like mine Thumbs Up FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
Ex 2016 135i M Sport - dream car
Ex 2003 RS6 Avant - piece of cr*p
Ex 2014 320d X Drive, M Sport Touring - ok I guess
Ex 2007 RRS TDV8 - bloody loved it
EX 2007 FL2 XS - not so bad
Post #377810 Fri Mar 22 2013 12:30pm
austencameron
thankyou all for the help, located near the driver side under transmition cover, new fuel filter fitted.
Post #377845 Fri Mar 22 2013 5:23pm
cossiedave
England 2006 Range Rover Sport TDV6 Autobiography Zambezi Silver
I changed mine and now the bloody water in fuel light comes on and I didn't re fit my sensor lol
Post #377850 Fri Mar 22 2013 6:22pm
mjbrr
United Kingdom 2009 Range Rover Sport TDV8 HSE Santorini Black
I get this about every 6 months or so and just clears by itself Confused 2009 3.6 TDV8 HSE Santorini Black
Post #377851 Fri Mar 22 2013 6:46pm
