Home > Maintenance & Modifications > TDV8 Exhaust Tips
JPR 1
TDV8 Exhaust Tips
Any suggestions on tips for a 2010 MY TDV8. Has downward pipes and looking to bling a little with outward exhaust tips.
I have seen loads on FleaBay etc, can anyone suggest a good make etc Thumbs Up
Post #377471 Tue Mar 19 2013 1:37pm
funnyguy1
United States 2009 Range Rover Sport 4.4 V8 HSE Santorini Black
I put a set of Supercharged exhaust and tail pipes on mine. Looks terrific. mike murphy
Post #377673 Thu Mar 21 2013 3:19am
JPR 1
Good idea, may look into this. Thumbs Up
Post #377681 Thu Mar 21 2013 8:39am
HICKY555
England 2008 Range Rover Sport TDV6 HSE Alaska White
http://www.rrsport.co.uk/forum/topic30096.html
CHECK THIS POST Thumbs Up RANGE ROVER SPORT 2008
White is the new Black
Post #377686 Thu Mar 21 2013 9:15am
JPR 1
Yes saw this, but 90mm wide is massive Whistle
Post #377690 Thu Mar 21 2013 9:26am
HICKY555
NOT TO BAD once fitted Very Happy RANGE ROVER SPORT 2008
Post #377695 Thu Mar 21 2013 10:04am
Hi Hicky
Did you drill locator holes to fit your VW reflectors?
I'm in 2 minds whether to use the gripping luggs (this would involve drilling my bumper) or cut off the luggs and glue them on
Thumbs Up RRS gone
Post #377696 Thu Mar 21 2013 10:07am
HICKY555
I cut off the lugs and used double sided 3m tape the type you use for number plates Thumbs Up at least this way you could take them off at any time Very Happy RANGE ROVER SPORT 2008
Post #377697 Thu Mar 21 2013 10:16am
cheers Thumbs Up
Trip to halfrauds then Mr. Green RRS gone
Post #377699 Thu Mar 21 2013 10:22am
RRSNorway
Norway 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Will it stay on during carwash etc? I'm getting mine today I hope. RRS 2006 2.7 HSE
Post #377716 Thu Mar 21 2013 2:16pm
HICKY555
OH YES Thumbs Up Its the same tape they use on the bonnet lettering Chawton White RANGE ROVER SPORT 2008
Post #377722 Thu Mar 21 2013 2:29pm
RRSNorway
Mine arrived today Thumbs Up
Did you just cut of the lugs or did you remove the hole red plastic plate on the back?
Since the back is uneven it would be best with a straight base? RRS 2006 2.7 HSE
Post #377852 Fri Mar 22 2013 5:59pm
HICKY555
JUST THE LUGS. FILL THE INDENT WITH ONE PIECE OF TAPE THEN A SECOND ON TOP WHEN YOU'VE REMOVED THE TAPES BACKING PAPER Thumbs Up RANGE ROVER SPORT 2008
Post #377858 Fri Mar 22 2013 6:25pm
Fatandre
Iceland 2006 Range Rover Sport Supercharged Santorini Black
What tips are those? 91 BMW 850CSI
Post #377884 Fri Mar 22 2013 9:20pm
HICKY555
ADAMECH. SEE MY LINK ABOVE. WHEN ORDERING ASK FOR 10% RRSPORT DISCOUNT I ARRANGED Thumbs Up RANGE ROVER SPORT 2008
Post #377943 Sat Mar 23 2013 11:36am
