![]() | Home > Maintenance & Modifications > TDV8 Exhaust Tips |
funnyguy1 Member Since: 18 Jun 2009 Location: Sun Valley Idaho Posts: 171 ![]() ![]() ![]() |
I put a set of Supercharged exhaust and tail pipes on mine. Looks terrific. mike murphy |
JPR 1 Member Since: 29 Jan 2013 Location: Cheshire Posts: 435 ![]() ![]() ![]() |
Good idea, may look into this. |
HICKY555 Member Since: 27 Jan 2013 Location: WORCESTER Posts: 208 ![]() ![]() ![]() |
http://www.rrsport.co.uk/forum/topic30096.html
Yes saw this, but 90mm wide is massive |
Hi Hicky
I cut off the lugs and used double sided 3m tape the type you use for number plates |
cheers |
RRSNorway Member Since: 08 Jan 2012 Location: norway Posts: 314 ![]() ![]() ![]() |
Will it stay on during carwash etc? I'm getting mine today I hope. RRS 2006 2.7 HSE |
OH YES |
Mine arrived today ![]() Did you just cut of the lugs or did you remove the hole red plastic plate on the back? Since the back is uneven it would be best with a straight base? RRS 2006 2.7 HSE |
JUST THE LUGS. FILL THE INDENT WITH ONE PIECE OF TAPE THEN A SECOND ON TOP WHEN YOU'VE REMOVED THE TAPES BACKING PAPER |
Fatandre Member Since: 05 Oct 2009 Location: Reykjavík Posts: 402 ![]() ![]() ![]() |
What tips are those? 91 BMW 850CSI |
ADAMECH. SEE MY LINK ABOVE. WHEN ORDERING ASK FOR 10% RRSPORT DISCOUNT I ARRANGED |
