Home > Technical > Help. Amber lights, HDC fault, parking brake fault etc.
Kristian_TT
2005 Range Rover Sport TDV6 HSE Cairns Blue
My dash is lighting up as a christmas tree and the dash shows error messages on hdc, parking brake, suspension lowering and special programs. The speedo is also dead.
Can it be a faulty speed sensor?
Post #374584 Sun Feb 24 2013 7:09pm
s335
Check the battery, as if its not fully charged it will shut things down
Post #375652 Mon Mar 04 2013 10:55pm
Markos
Slovenia 2008 Range Rover Sport TDV8 HSE Java Black
Kristian I had similar problem and as it turned out the problem was in a fuel filter and that was because the fuel pump was not letting enough fuel through, so the car started turning special programs off, HDC....lowering suspension.
Markos 2008 RRS TDV8 HSE, Java black, Alpaca,.....
Post #375716 Tue Mar 05 2013 1:03pm
