You are currently viewing RRSPORT.CO.UK as a guest - Register to take part or Log In
Home > Technical > Help. Amber lights, HDC fault, parking brake fault etc.
Kristian_TT
My dash is lighting up as a christmas tree and the dash shows error messages on hdc, parking brake, suspension lowering and special programs. The speedo is also dead.
Can it be a faulty speed sensor?
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated
Sun Feb 24 2013 6:09pm
s335
Check the battery, as if its not fully charged it will shut things down
Mon Mar 04 2013 9:55pm
Markos
Kristian I had similar problem and as it turned out the problem was in a fuel filter and that was because the fuel pump was not letting enough fuel through, so the car started turning special programs off, HDC....lowering suspension.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
