![]() | Home > Technical > Tow bar Wiring? |
You might find the car has been spec'd with it.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4421 ![]() ![]() ![]() |
Fitted a set today, took little over half an hour. If you go for the genuine electrics, they should be enabled by a diagnostic computer capable of modifying the cars CCF. They will work even if you don't enable them, but it will stop the PDC from coming on when you have a trailer connected, and similar other things
