Home > Technical > Tow bar Wiring?
jakeob
England 2007 Range Rover Sport TDV8 HST Java Black
Tow bar Wiring?
Does the RRS come ready to plug a trailer into?
its a hse 2007
If not is it a big job to get it wired up? I only need to use it a couple of times towing my kit car for repairs
Post #373888 Mon Feb 18 2013 4:41pm
You might find the car has been spec'd with it.
Take a look behind the towing eye cover and see if the plugs are there.
If not, you can get the wiring for around £100 I believe and it is fairly simple to put in (according to other people, far too technical for me Wink ).
I recall there is also something about activating it via the system, but I'm sure someone more knowledgeable will be along soon. Thumbs Up ON THE WAY: BMW F21 M140i
Post #373889 Mon Feb 18 2013 4:48pm
Disco_Mikey
Fitted a set today, took little over half an hour. If you go for the genuine electrics, they should be enabled by a diagnostic computer capable of modifying the cars CCF. They will work even if you don't enable them, but it will stop the PDC from coming on when you have a trailer connected, and similar other things
If you opt for the aftermarket electrics, they take a bit longer to fit, but don't need enabled. Your PDC will still try and work though
Post #373904 Mon Feb 18 2013 7:38pm
