![]() | Home > General > Not so bullet proof TDV8 |
StuRRS Member Since: 18 Jan 2013 Location: Gloucestershire Posts: 92 ![]() ![]() |
Very pleased for you that you have finally got this sorted |
Nik Member Since: 19 Nov 2010 Location: Up North Posts: 657 ![]() ![]() ![]() |
One wonders which unlucky sod will end up buying your sport, or are LR doing the decent thing and scrapping it?
I suspect it will reappear on the market as the cost of engine, turbos and now gearbox, then another engine as I don't believe for one minute that the noise is gearbox, will mean someone will want to get something back. The car will no doubt go into auction when its finally fixed. I did say it should be scrapped, but it is a nice car and if fixed should now be reliable, it has had virtually everything replaced after all |
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5637 ![]() ![]() |
Simon - I couldn't agree more - especially the last paragraph |
PS
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 ![]() ![]() ![]() |
Simon, I'm so pleased that you got a solution in the end, is Guy Salmon owned by Sytner? If so I have just had a similar example of brilliant service at Audi Reading, 3 year old A3 Cabriolet with slight wear to the hood all replaced under warranty. Audi warranty dragged their heels and Audi Reading covered the cost of a brand new Audi A4 loan car for three weeks, nothing was too much trouble! Well done Sytner...keep up the good work. |
Simon, can you return the boiled sweet with pocket fluff that I sent in your emergency supplies box, now you have a butler, they tend to remove all the good fluff from sweets before serving after your tiffin..... |
Ian. The sweet was a life saver as by 6 I was drowning in coffee and chewy biscuits. Was even offered lunch or they would send out for sandwiches |
Simon - fantastic that you can finally put this all behind you |
No such luck for you BC, my routes are firmly here not on the posh side. If I could have found a similar spec vehicle in Sytner network I would have stayed with a Sport! Only reason I went Fullfat was price and car was right, and having had three fault free years in one, looked a good option.
MisterAdam Member Since: 03 May 2012 Location: Liverpool, UK Posts: 352 ![]() ![]() ![]() |
I've followed this topic from the start and it's been quite a read, and quite an ordeal to have to of gone through |
At least my phone is safe. Chucked a few after hanging up calls |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
If you know what the registration will be when your private registration is removed, post the registration the lemon to warn others,
