Home > Technical > Heated Screen problems
madmackie
United Kingdom 2005 Range Rover Sport TDV6 HSE Bonatti Grey
HI all can anyone shed any light on this
went out o my car this morning put the fornt and rear heated screens on to get rid of the frost the rear screen cleared half way down then two lines didnt clear then another two did and the bottom line didnt.
The front screen the passenger side cleared fully and part of the drivers side the remaining bit of the drivers side really struggled to clear
is this down to a bad connection or are the elements in the screens on their way out Big Cry both screens are the original the car is a 55 plate rrs hse
any advice or suggestions please thanks in advance pete
Post #369576 Wed Jan 16 2013 10:18am
I'd guess the elements are on their way out, it probably won't get any worse to be honest, its just how these things seem to go.
Post #369578 Wed Jan 16 2013 10:26am
kav1187
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
The elements have probably got gaps in them on the rear screen. This stuff can be used to repair the gaps in the elements that aren't working in the rear...
http://www.halfords.com/webapp/wcs/stores/...yId_255229
On the front screen, the left side clears quicker than the right because of the shorter distance between screen and battery so the current is stronger on the left side. Are some of the elements not working on your front screen or is it just that it's taking longer?
I fitted heated screens to my VW golfs and there are two sets of connections - one for left and one for right hand side of the screen - I'm confident that the RRS setup will be the same. Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section Thumbs Up
http://rrsport.co.uk/forum/topic28424.html
Post #369616 Wed Jan 16 2013 2:57pm
madmackie
If i remember the front do all work just the drivers side take ages and possibly some of the elements are not working i will check tomorrow as this morning i used the blower also to clear the screen and thanks i will take a look at the element repair thanks pete
Post #369620 Wed Jan 16 2013 3:02pm
kav1187
Might be worth checking your alternator is keeping up with the demand from the screens. Turn the screens on and see what the voltage is on the battery. Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section Thumbs Up
Post #369630 Wed Jan 16 2013 5:23pm
madmackie
Had a close look at the rear screen and some of the elements seem to appear broke so i have used a bit of the paint as posted earlier so i will see what happens with that would it be worth trying to find the connectors on the drivers side front screen and maybe cleaning them thanks all pete
Post #369634 Wed Jan 16 2013 5:46pm
kav1187
Yep always worth checking. No idea where they are Im sure someone can point you in the right direction. Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section Thumbs Up
Post #369641 Wed Jan 16 2013 6:45pm
madmackie
If someone could that would be good thanks
Post #369643 Wed Jan 16 2013 6:52pm
Glohh
United Kingdom 2012 Range Rover Sport 3.0 TDV6 Autobiography Siberian Silver
I’ve noticed the range rover has privacy glass on the back was this done recently? If so, was there a previous tint on before this that was taken off ? With time the elements do tend to break but this is more to do with human interaction with the part. There are different ways you can test if you are familiar with an electrical voltmeter simple continuity tests on the failed lines and pin point the problem. Glohh.
Automotive light designers and manufacturers.
Available now The GL-3 Taillight for the Range Rover Sport.
www.glohh.com
www.facebook.com/glohh
Post #369650 Wed Jan 16 2013 7:31pm
kav1187
Pete, please see Wiggs' reply from another post...
wiggs wrote:
"A" pillar trim comes off no problem ...no airbag will deploy
There are 2 electrical connectors for each side of the windscreen ..there are also 2 fuse's one for each side
There is a video on how to remove the A pillar trim in the definitive 'how to 'thread linked in my signature Thumbs Up
Im not so sure a continuity test will work as there will be continuity through the other lines above...they're all joined together. Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section Thumbs Up
Post #369717 Thu Jan 17 2013 12:16am
madmackie
thanks Kav will look at it cheers
Post #369722 Thu Jan 17 2013 8:15am
Glohh
Hey
Yep a continuity test would make a complete circuit as the whole grid is basically a parallel circuit. Banging Head So the best method would be close up visual
inspection of the elements and bridging the breaks as necessary. Glohh.
www.glohh.com
Post #369815 Thu Jan 17 2013 6:25pm
MBaker
Can anyone tell me where the plugs are located? The ones that have the seal and are really tight to plug in.
Drivers side not working on mine.
Fuses both ok, relay seems fine so just need to check if the plugs are melted/not connected properly.
Just can't seem to find them.
Cheers,
Mike.
Post #403387 Sat Nov 23 2013 7:22pm
MBaker
Anyone know where these plugs are located?
It's getting colder and I'd like to get this sorted.
Many thanks.
Mike.
Post #404494 Sun Dec 01 2013 8:30pm
