Home > In Car Electronics > Using bluetooth to stream music
hotlatte
2007 Range Rover Sport TDV6 HSE Alaska White
Hi,
Is there a way to stream music directly from my Iphone to listen to music using car stereo system. May be by installing some sort of module or a toy. I know we have Bluetooth facility linked through in car speakers to make and receive calls
Thanks in advance
Post #369043 Fri Jan 11 2013 5:13pm
Don't think this was a feature until MY12 cars Neutral ON THE WAY: BMW F21 M140i
Post #369045 Fri Jan 11 2013 5:16pm
hotlatte
dont suppose you could install a module or a part somewhere and have it configured to work. I am sure someone out-there would have a had a go. Dont really want to install the iphone dock to be honest.
Post #369047 Fri Jan 11 2013 5:26pm
You need someone a bit more 'techy' than me to answer that one Embarassed ON THE WAY: BMW F21 M140i
Post #369048 Fri Jan 11 2013 5:28pm
kav1187
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Hotlatte, how about connecting a double ended headphone cable between the aux socket in the car and the headphone socket on your phone? Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section Thumbs Up
http://rrsport.co.uk/forum/topic28424.html
Post #369049 Fri Jan 11 2013 5:34pm
Paddi
For superior sound you could use one of these http://compare.ebay.co.uk/like/13059062180...amp;crdt=0 uses the iphone line out instead of headphone socket so much better than jack to jack.
There are also these http://www.ebay.co.uk/itm/Bluetooth-Stereo...0659372788 but haven't tried one myself. Can the phone connect by bluetooth to more than one device at a time? I don't know but am willing to bet somebody who does will be along soon. 2008 MY Java Black TDV8 HSE
Post #369063 Fri Jan 11 2013 7:16pm
mrfixit
2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Yes the ebay linked item will plug into the aux socket and your phone will connect to it and the bluetooth module to make and receive calls.
Volume will be lower than the radio or cd but this seems a trait of the aux socket.
Post #369082 Fri Jan 11 2013 10:07pm
