Home > Faults & Fixes > Reverse sensors...Screech stays on..
Rover T
Ireland 2008 Range Rover Sport TDV6 HSE Stornoway Grey
When i put the RR into reverse or D at the house the reverse sensor beeep noise comes on but stays on with a constant screech,even though nothing is in front or behind???.When i change intio D, to drive off forwards the screech stays on until i reach a certain speed then knocks off. I have checked the sensors and all ,both front and back are clicking???I had the engine,gearbox and transfer box ecu's all updated about a week ago,could this be at fault??? Any ideas......
Post #367333 Fri Dec 21 2012 3:10pm
Bodsy
Site Sponsor
Did the constant tone thing happen as soon as you got in it after updates or has it been a while afterwards?
Really need to get the fault codes read TBH Thumbs Up
It could be one that even though its clicking to show its working the relay, it may have a dodgy circuit giving greater or less resistance meaning it thinks its got something in front of it. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #367375 Fri Dec 21 2012 8:26pm
Rover T
Rev sens....
It worked fine for a week or more after the upgrades, forgot to mention, i have no error codes????
Post #367451 Sat Dec 22 2012 7:29pm
DrNick_B
United Kingdom 2008 Range Rover Sport TDV8 HSE Bonatti Grey
Had this problem on my 58 plate RRS TDV8 last year during the really wet spell and JLR replaced both front and rear PDC sensor wiring harnesses under warranty because of "water ingress".
It stops above a certain speed because the PDC switches off above a certain speed until reverse gear is seected again
Good luck...
Post #370891 Thu Jan 24 2013 9:37pm
Rover T
Just thinking about what you said and mine only gives trouble in damp wet weather ???more investigation???
Post #370962 Fri Jan 25 2013 4:37pm
Rover T
Any one got the part no,s for the harnesses??
Post #370963 Fri Jan 25 2013 4:38pm
Colin7524
United Kingdom 2005 Range Rover Sport TDV6 S Java Black
Sensors
Did you get this sorted
Post #599712 Fri Jun 05 2020 9:21am
triplemmm
I hope he did otherwise having that screeching for 7 years would drive you crazy
Post #599898 Mon Jun 08 2020 9:20pm
