Home > Faults & Fixes > Reverse sensors...Screech stays on.. |
Rover T Member Since: 11 Oct 2012 Location: West Posts: 11 |
When i put the RR into reverse or D at the house the reverse sensor beeep noise comes on but stays on with a constant screech,even though nothing is in front or behind???.When i change intio D, to drive off forwards the screech stays on until i reach a certain speed then knocks off. I have checked the sensors and all ,both front and back are clicking???I had the engine,gearbox and transfer box ecu's all updated about a week ago,could this be at fault??? Any ideas...... |
Fri Dec 21 2012 3:10pm |
Did the constant tone thing happen as soon as you got in it after updates or has it been a while afterwards?
Fri Dec 21 2012 8:26pm |
It worked fine for a week or more after the upgrades, forgot to mention, i have no error codes???? |
Sat Dec 22 2012 7:29pm |
Just thinking about what you said and mine only gives trouble in damp wet weather ???more investigation??? |
Fri Jan 25 2013 4:37pm |
Any one got the part no,s for the harnesses?? |
Fri Jan 25 2013 4:38pm |
Colin7524 Member Since: 19 Jul 2019 Location: Sussex Posts: 7 |
Did you get this sorted |
Fri Jun 05 2020 9:21am |
triplemmm Member Since: 22 Mar 2014 Location: SE Posts: 77 |
I hope he did otherwise having that screeching for 7 years would drive you crazy |
Mon Jun 08 2020 9:20pm |
