![]() | Home > General > Steering round right hand corners |
1st port of call would be to check the alignment |
Lovey Member Since: 22 Nov 2012 Location: East Sussex Posts: 12 ![]() ![]() ![]() |
Hi,
Specialist job, check www.alignmycar.co.uk to find a local specialist with the right equipment |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4420 ![]() ![]() ![]() |
1st post of call should be tyre pressures |
Nik Member Since: 19 Nov 2010 Location: Up North Posts: 657 ![]() ![]() ![]() |
Garage.
2015 Golf R DSG Gone 2013 Mercedes C220 CDi AMG Sport Plus Gone 2008 2.7 RRS HSE |
Also check your nuts |
Hi Ady
Next step i'd get it to a garage and get all steering joints checked aswel as wheel bearings.Just out of intrest what wheels have you got on your motor? |
Ady
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 ![]() ![]() ![]() |
Probably an ARB issue. Does yours have dynamic stability control?
rogerpop Member Since: 14 Jul 2012 Location: blackpool, Lancashire Posts: 14 ![]() ![]() |
Could be wheel bearing. Just done mine. Fairly easy job. |
Mitchmx Member Since: 22 Jul 2012 Location: Bristol Posts: 156 ![]() ![]() |
I had the same problem a few months ago. It's been fine since and not done it.
Sorry somehow missed the bit where it says it was grinding. Transmission or CV joint would be my guess. Try putting the steering on full lock left/right and drive forward slowly. Get someone to listen to the wheels to see if there is a clicking sound as you go round. If it clicks then it's probably a CV joint. |
Rangster Member Since: 22 Nov 2012 Location: Stoke on Trent Posts: 30 ![]() ![]() ![]() |
Sounds like the DSC (Dynamic Stability Control). I've had the same issue on right hand corners at anything more than slow speed.
