Home > General > Steering round right hand corners
Lovey
England 2009 Range Rover Sport TDV8 HSE Bourneville
When I drive round a right hand bend the steering seems to go drift, and feels very unstable and unsafe, left hand bend seem fine, at slow speed it's ok but a a higher speed the problem occurs. Also twice now I have gone tight round a roundabout and I have had a grinding noise from the front, is this traction control coming on or could this be linked to the steering or something else.
Any help or advise would be appreciated and welcomed.
Many,thanks
Steve
Post #367048 Tue Dec 18 2012 9:01pm
1st port of call would be to check the alignment Thumbs Up RRS gone
Post #367052 Tue Dec 18 2012 9:42pm
Lovey
Is this something that I can do or is it a garage job.
Thanks
Steve
Post #367053 Tue Dec 18 2012 9:46pm
Specialist job, check www.alignmycar.co.uk to find a local specialist with the right equipment Thumbs Up ON THE WAY: BMW F21 M140i
Post #367055 Tue Dec 18 2012 9:51pm
Disco_Mikey
1st post of call should be tyre pressures Whistle Thumbs Up
Post #367056 Tue Dec 18 2012 9:52pm
Nik
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Garage.
Lovey wrote:
Thanks
Steve
 2015 Golf R DSG
Gone 2013 Mercedes C220 CDi AMG Sport Plus
Gone 2008 2.7 RRS HSE
Post #367057 Tue Dec 18 2012 9:52pm
Also check your nuts Laughing
I don't mean check to see if you are nuts, Laughing i mean check to see if your wheel nuts are all present and tight. Thumbs Up
Even if they are bolts on the sport, still check them.
Post #367058 Tue Dec 18 2012 10:02pm
Lovey
Hi Ady
Nuts are tight and tyre pressure is good.
Post #367060 Tue Dec 18 2012 10:33pm
Next step i'd get it to a garage and get all steering joints checked aswel as wheel bearings.Just out of intrest what wheels have you got on your motor?
Post #367061 Tue Dec 18 2012 10:39pm
Lovey
Ady
20" Stormer wheels
Steve
Post #367062 Tue Dec 18 2012 10:46pm
kav1187
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Probably an ARB issue. Does yours have dynamic stability control?
Check the ARB link rods on both sides in case one has snapped.
Post #367065 Tue Dec 18 2012 11:10pm
rogerpop
2008 Range Rover Sport TDV8 HSE Santorini Black
Could be wheel bearing. Just done mine. Fairly easy job.
Post #367074 Wed Dec 19 2012 8:34am
Mitchmx
I had the same problem a few months ago. It's been fine since and not done it.
Going around a tight small roundabout was fine but at about 25 30 around a big roundabout it sometimes grinded Worse if you lift your foot off the throttle and the front dips. Just like abs coming in. I had it all checked. But was fine and not done it for a few months now.
Not much help this but thought ide post it anyway. Rolling Eyes
Post #367075 Wed Dec 19 2012 9:19am
kav1187
Sorry somehow missed the bit where it says it was grinding. Transmission or CV joint would be my guess. Try putting the steering on full lock left/right and drive forward slowly. Get someone to listen to the wheels to see if there is a clicking sound as you go round. If it clicks then it's probably a CV joint.
Post #367078 Wed Dec 19 2012 9:50am
Rangster
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Stornoway Grey
Sounds like the DSC (Dynamic Stability Control). I've had the same issue on right hand corners at anything more than slow speed.
The grinding is the ABS kicking in. Check for warning lights activated on the dash at the same time as the vehicle feels strange and the grinding occurs.
It could be the steering angle that is out, or steering angle sensor at fault.
Search the forum for more info on the DSC. RRS TDV8 MY2010 Stornoway Grey
Full Exterior Autobiography Factory Upgrade
Piano Black Interior Trim inc Steering Wheel
Ivory Premium Perforated Leather
22" 5 spoke "Style 7" Diamond Turned Alloys
Towing Pack
Diesel Tuning Box
Privacy Glass
Side Steps
Best vehicle I've ever driven.
Current garage also includes;
Mercedes 320 CDI CLS
TVR Tuscan S
Post #367241 Thu Dec 20 2012 6:44pm
