Home > Technical > Light Steering!!
Tony666
2005 Range Rover Sport TDV6 HSE Bonatti Grey
Light Steering!!
Any advice greatly appreciated.
My 2005 RRS sems to have very light steering. It's the only RRS I've driven so difficult for me to compare, but I have driven a full fat and it seemed firmer. The issue is that if I'm on a dual carriageway or Motorway I'm constantly making tiny adjustments to the wheel to keep the car straight. Tyres are correctly inflated, and it doesn't pull to any particular direction. It's not a major problem but I'd be happier with a heavier feel and a tendancy to stay straight. Is this usual for the RRS or have I got a problem?
Post #366569 Thu Dec 13 2012 11:54pm
rigsby
I would say you had a problem. Mine stays straight and feels firm and true. Maybe front suspension bushes? Im sure someone with more of an idea than me will be along to help in a bit Thumbs Up MY16 AUTOBIOGRAPHY Indus silver with some toys
2012 3.0 SDV6 Luxury gone, but a great motor
Post #366570 Fri Dec 14 2012 12:15am
Tony666
Thanks for that. MOT soon so maybe they'll pick something up then?
Post #366571 Fri Dec 14 2012 12:37am
Do sports have speed sensitve steering Question If so, then it might be a sensor that has failed.
Post #366572 Fri Dec 14 2012 8:29am
muddywheels
Milk Float Man
How long have you had it Question
I came from a fl2 to a RRS and found the steering very sensitive especially on the contis but now on Pirelli and feels normal now Thumbs Up Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #366575 Fri Dec 14 2012 9:33am
A 4-wheel alignment check wouldn't be a bad thing. You could have an error that is symmetrical across the car so it tracks straight but is overly sensitive. Excess toe-out might cause this but then you'd also expect to see uneven tyre wear on the front shoulders. 2012 SDV6 - it's missing a couple of cylinders
Post #366596 Fri Dec 14 2012 12:08pm
Bodsy
Site Sponsor
I'd say check the bushes of the wishbones first and ARB bushes, then if they're all OK, go for a full 4 wheel alignment on a Hunters Geometary machine. You should als get a before and after printout so you know which bits are out. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #366623 Fri Dec 14 2012 3:35pm
Tony666
Thanks for the input guys, some interesting stuff there. I'll take the car for the mot soon and get under the ramp for a good look, if nothing obvious then the alignment. I don't think it's tyre or wheel related as I've recently changed them and no different. Any further advances on whether the sport has speed sensitive steering?
Post #366745 Sun Dec 16 2012 9:17am
Tony666
Well I've since had proper 4-Wheel Alignment carried out and new ARB bushes fitted and the car does feel better, though the steering is still light. I recently drove a friends Disco 3 which felt considerably heavier and firmer???
Post #407714 Wed Jan 01 2014 12:15pm
muddywheels
Milk Float Man
Now have a my13 and the steering feels much better than my10 especially on dynamic setting Thumbs Up Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #407716 Wed Jan 01 2014 12:26pm
adigorn
yes it does an defo worth look at Thumbs Up
Post #407724 Wed Jan 01 2014 1:18pm
AndyLandy
England 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Hi,
Does it happen on all roads, ours hates the truck ruts and over banding?
It does not do it on other, smoother roads.
Just a thought. Rules are for the obediance of fools and the guidence of wise men
Post #407777 Wed Jan 01 2014 6:53pm
Tony666
Yep, all roads, just feels light, I need to drive another similar age/spec car to get a better idea I think.....
Post #407794 Wed Jan 01 2014 10:22pm
Tony666
Unfortunately I spend most of my time on smooth roads, if anyone can enlighten me as to where in South Wales or Hereford/birmingham area I can play off road without bashing up my beloved car please let me know!!
Post #407795 Wed Jan 01 2014 10:25pm
