Home > Technical > Light Steering!! |
rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879 |
I would say you had a problem. Mine stays straight and feels firm and true. Maybe front suspension bushes? Im sure someone with more of an idea than me will be along to help in a bit MY16 AUTOBIOGRAPHY Indus silver with some toys
Thu Dec 13 2012 11:15pm |
Tony666 Member Since: 26 Jul 2011 Location: Barry Posts: 170 |
Thanks for that. MOT soon so maybe they'll pick something up then? |
Thu Dec 13 2012 11:37pm |
Do sports have speed sensitve steering If so, then it might be a sensor that has failed. |
Fri Dec 14 2012 7:29am |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 |
How long have you had it
Fri Dec 14 2012 8:33am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8983 |
A 4-wheel alignment check wouldn't be a bad thing. You could have an error that is symmetrical across the car so it tracks straight but is overly sensitive. Excess toe-out might cause this but then you'd also expect to see uneven tyre wear on the front shoulders. 2012 SDV6 - it's missing a couple of cylinders
Fri Dec 14 2012 11:08am |
I'd say check the bushes of the wishbones first and ARB bushes, then if they're all OK, go for a full 4 wheel alignment on a Hunters Geometary machine. You should als get a before and after printout so you know which bits are out. Bodsys Brake Bible
Fri Dec 14 2012 2:35pm |
Thanks for the input guys, some interesting stuff there. I'll take the car for the mot soon and get under the ramp for a good look, if nothing obvious then the alignment. I don't think it's tyre or wheel related as I've recently changed them and no different. Any further advances on whether the sport has speed sensitive steering? |
Sun Dec 16 2012 8:17am |
Well I've since had proper 4-Wheel Alignment carried out and new ARB bushes fitted and the car does feel better, though the steering is still light. I recently drove a friends Disco 3 which felt considerably heavier and firmer??? |
Wed Jan 01 2014 11:15am |
Now have a my13 and the steering feels much better than my10 especially on dynamic setting Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Wed Jan 01 2014 11:26am |
adigorn Member Since: 17 Mar 2010 Location: Birmingham Posts: 110 |
yes it does an defo worth look at |
Wed Jan 01 2014 12:18pm |
AndyLandy Member Since: 26 Nov 2013 Location: Bassingbourn Posts: 39 |
Wed Jan 01 2014 5:53pm |
Yep, all roads, just feels light, I need to drive another similar age/spec car to get a better idea I think..... |
Wed Jan 01 2014 9:22pm |
Unfortunately I spend most of my time on smooth roads, if anyone can enlighten me as to where in South Wales or Hereford/birmingham area I can play off road without bashing up my beloved car please let me know!! |
Wed Jan 01 2014 9:25pm |
