Home > Technical > Terrain response problem locking rear wheeel |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8982 |
Have you tried turning off the DSC? 2012 SDV6 - it's missing a couple of cylinders
Sun Dec 09 2012 12:20am |
sampson321 Member Since: 15 Jul 2012 Location: bristol Posts: 8 |
Turning the DSC off makes know difference. still makes the ns rear wheel lock. Think the next option is go for a diognostic test as there are no warning on the dash. |
Sun Dec 09 2012 9:28am |
It does sound like a sensor somewhere is giving a weird output and the system is trying to compensate for a non-existent situation. Perhaps the wheel speed sensor is failing and the TC thinks the wheel is spinning up when it isn't so it applies the brake to that wheel to slow it down. 2012 SDV6 - it's missing a couple of cylinders
Sun Dec 09 2012 10:18am |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
As the braking system doesn't have ability to apply one brake at a time as far as I know, sounds more like a diff problem but a read of fault codes may show up a fault code relating to wheel speed that goes to TC. DSC on these cara never fully switches off in certain modes but read of owners manual should show what does what and when. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Sun Dec 09 2012 12:49pm |
disco4x4au Member Since: 17 Nov 2009 Location: Perth Posts: 147 |
When activated by the traction control system, yes it does. Cheers, Gordon 2015 RRS SDV6 SE, Santorini Black, GOE 2-way HS rods, Traxide dual battery, 275/55R20 Nitto TerraGraplers 2015 Discovery 4 SDV6 HSE - GOE 3-way HS rods, GOE underbody plates and sliders, 275/65R18 Courgia MT |
Tue Dec 11 2012 1:59am |
Very true - its the feature, independant control of each wheel speed...that also part of HDC and TC...otherwise it wouldnt work properly Mike 2014 Facelift Discovery |
Tue Dec 11 2012 4:03pm |
