Home > Technical > Terrain response problem locking rear wheeel
sampson321
Hi guys
My 2007 tdv8 has become a nightmare and laughing stock among freinds. When driving in wet slidey fields the terrain response decides to jam the N/s rear wheel on for no reason. I am on road tyres but traveling fine until the wheel jams on then im stuck.
Friends in disco 3's and P38 just drive by laughing. Doesn't matter what programme i select or if im in high or low range.
Any ideas??
Thanks
Post #365927 Sat Dec 08 2012 10:10pm
Have you tried turning off the DSC? 2012 SDV6 - it's missing a couple of cylinders
Post #365951 Sun Dec 09 2012 12:20am
sampson321
Turning the DSC off makes know difference. still makes the ns rear wheel lock. Think the next option is go for a diognostic test as there are no warning on the dash.
Post #365975 Sun Dec 09 2012 9:28am
It does sound like a sensor somewhere is giving a weird output and the system is trying to compensate for a non-existent situation. Perhaps the wheel speed sensor is failing and the TC thinks the wheel is spinning up when it isn't so it applies the brake to that wheel to slow it down. 2012 SDV6 - it's missing a couple of cylinders
Post #365981 Sun Dec 09 2012 10:18am
simple1
As the braking system doesn't have ability to apply one brake at a time as far as I know, sounds more like a diff problem but a read of fault codes may show up a fault code relating to wheel speed that goes to TC. DSC on these cara never fully switches off in certain modes but read of owners manual should show what does what and when. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #366000 Sun Dec 09 2012 12:49pm
disco4x4au
Australia 2013 Range Rover Sport SDV6 SE Santorini Black
When activated by the traction control system, yes it does.
Cheers,
Gordon 2015 RRS SDV6 SE, Santorini Black, GOE 2-way HS rods, Traxide dual battery, 275/55R20 Nitto TerraGraplers
2015 Discovery 4 SDV6 HSE - GOE 3-way HS rods, GOE underbody plates and sliders, 275/65R18 Courgia MT
Post #366216 Tue Dec 11 2012 1:59am
mse
Cheers,
Gordon
Very true - its the feature, independant control of each wheel speed...that also part of HDC and TC...otherwise it wouldnt work properly Mike
2014 Facelift Discovery
Post #366267 Tue Dec 11 2012 4:03pm
