Home > In Car Electronics > HDC FAULT/ TRACTION / SUSPENSION HELPPPPPPPPP
Harry HST
United Kingdom 2005 Range Rover Sport 4.4 V8 HSE Java Black
Hi
I've had a number of random errors shoot up today, HDC Transmission error, Traction error, Parking sensors stopped working, Battery drainage, suspension raises at times.
I have tried charging my battery for 12 hours yet still the same problem.
Has anyone else had this problem this has started out the blue!
I've got the car booked in to go to LR on Monday Confused
Anyone else had these issues?
Post #364057 Thu Nov 22 2012 1:18pm
SCdavies
England 2006 Range Rover Sport Supercharged Zambezi Silver
new battery required.
Post #364060 Thu Nov 22 2012 1:58pm
SCdavies
Sorry i was meant to say that a new battery sorted my issues out.
Post #364061 Thu Nov 22 2012 2:00pm
Big ken
Scotland 2005 Range Rover Sport TDV6 HSE Zermatt Silver
Same here Thumbs Up 2.7 TDV6
22" Stormer alloys
Side steps
PS3
Headrest monitors
Black badges
Stainless tailpipes
Privacy glass
L.E.D. lights throughout.
Post #364068 Thu Nov 22 2012 2:30pm
Could also be the alternator on the way out if it's not charging the battery Thumbs Up ON THE WAY: BMW F21 M140i
Post #364069 Thu Nov 22 2012 2:31pm
Harry HST
Hi Guys
Never had thought that a new battery can fix ALLLLL the electrical faults!!!
Just dont understand how a low powered battery can cause so many electrical problems.
I really hope that this is the case when it goes into LR as its under warranty as I've come across alsorts of horror stories on the net and stuff.
Will keep you posted.
Thanks Smile
Post #364124 Thu Nov 22 2012 9:45pm
A new battery won't be covered by the warranty (I'd be amazed if it is) but a new LR battery isn't that expensive.
A new alternator should be covered by the warranty though. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #364135 Thu Nov 22 2012 10:14pm
mse
A good battery should have a warranty Mike
2014 Facelift Discovery
Post #364137 Thu Nov 22 2012 10:16pm
Only an aftermarket one and then likely only with proof of purchase (and probably a load of other restrictions on claims) 2012 SDV6 - it's missing a couple of cylinders
Post #364147 Thu Nov 22 2012 10:39pm
Harry HST
As mentioned never knew such a weak battery can trigger all the problems listed.
Post #364154 Thu Nov 22 2012 11:33pm
The problem seems to be that the RRS uses a lot of sensors and several ECUs. These are connected by a CANBUS and it seems, from the symptoms anyway, that an error in one place can cause a cascade error through several systems. Anything which is voltage sensitive will be susceptible to an issue with the battery or charging system, for example. Quite a few error codes are generated by "signal voltage too high" and "signal voltage too low"
If you have a series of interconnected systems each of which might rely on data from other systems then an error in one can cause several others to also report errors even where they aren't actually seeing a real error in their own system. Quite why there isn't an error trapping system is beyond me. Or maybe the multiple errors are done on purpose and meant to force the user to go to a garage ASAP. 2012 SDV6 - it's missing a couple of cylinders
Post #364157 Fri Nov 23 2012 12:15am
mse
The land rover ones come with warranty - 3yrs on the original, at least 12 months on the replacement.
The batteries i buy now have 3 year warranties and ive had 2 replacements on one of them just by walking in.
Samson batteries we used to get had lifetime warranties.
The Lucas batteries i bought from their outlet had a 3yr warranty - but i never needed to return that as i sold the car Mike
Post #364188 Fri Nov 23 2012 10:12am
Harry HST
Thanks for this information its very useful.
I purchased a used RS from LR in Swansea and they have given me a 6 months warranty.
I have clearly made the business manager aware that these faults have come up and need to be rectified, I have also made him aware that I think it may well be the battery.
He has stated not to worry and that LR will collect the vehicle and have a look at the issues for me on Monday
Are they obliged to charge me for replacing the battery or will they ask for my permission before replacing anything?
Thanks
Post #364215 Fri Nov 23 2012 1:20pm
mse
Any chargable work they should ask your permission over first - unless you gave it when handing the vehicle over (which is dodgy if added to part of the form) Mike
Post #364217 Fri Nov 23 2012 1:31pm
You wait until a brake bulb goes, the car goes into meltdown Laughing ....I kid you not from some of the stories on here Shocked ON THE WAY: BMW F21 M140i
Post #364218 Fri Nov 23 2012 1:47pm
