Home > In Car Electronics > HDC FAULT/ TRACTION / SUSPENSION HELPPPPPPPPP |
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 |
new battery required. |
Thu Nov 22 2012 1:58pm |
Sorry i was meant to say that a new battery sorted my issues out. |
Thu Nov 22 2012 2:00pm |
Big ken Member Since: 14 Nov 2011 Location: Airdrie Posts: 282 |
Same here 2.7 TDV6
Thu Nov 22 2012 2:30pm |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Could also be the alternator on the way out if it's not charging the battery ON THE WAY: BMW F21 M140i
Thu Nov 22 2012 2:31pm |
Harry HST Member Since: 09 Feb 2010 Location: Birmingham Posts: 296 |
Hi Guys
Thu Nov 22 2012 9:45pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8983 |
A new battery won't be covered by the warranty (I'd be amazed if it is) but a new LR battery isn't that expensive.
Thu Nov 22 2012 10:14pm |
A good battery should have a warranty Mike
Thu Nov 22 2012 10:16pm |
Only an aftermarket one and then likely only with proof of purchase (and probably a load of other restrictions on claims) 2012 SDV6 - it's missing a couple of cylinders
Thu Nov 22 2012 10:39pm |
As mentioned never knew such a weak battery can trigger all the problems listed. |
Thu Nov 22 2012 11:33pm |
The problem seems to be that the RRS uses a lot of sensors and several ECUs. These are connected by a CANBUS and it seems, from the symptoms anyway, that an error in one place can cause a cascade error through several systems. Anything which is voltage sensitive will be susceptible to an issue with the battery or charging system, for example. Quite a few error codes are generated by "signal voltage too high" and "signal voltage too low"
Fri Nov 23 2012 12:15am |
The land rover ones come with warranty - 3yrs on the original, at least 12 months on the replacement. The batteries i buy now have 3 year warranties and ive had 2 replacements on one of them just by walking in. Samson batteries we used to get had lifetime warranties. The Lucas batteries i bought from their outlet had a 3yr warranty - but i never needed to return that as i sold the car Mike 2014 Facelift Discovery |
Fri Nov 23 2012 10:12am |
Thanks for this information its very useful.
Fri Nov 23 2012 1:20pm |
Any chargable work they should ask your permission over first - unless you gave it when handing the vehicle over (which is dodgy if added to part of the form) Mike
Fri Nov 23 2012 1:31pm |
You wait until a brake bulb goes, the car goes into meltdown ....I kid you not from some of the stories on here ON THE WAY: BMW F21 M140i MERCEDES GL350 - Metallic Navy Blue w/Grey interior GOING: BMW F31 335D MSport+ xDrive Touring GONE: Land Rover Discovery 4 HSE - Stornaway Grey w/Black Interior (wish we'd kept it ) GONE: BMW F10 520D MSport - Carbon Black GONE:MY12 RRS SDV6 HSE Sumatra/Ivory/Grand Black Privacy glass |
Fri Nov 23 2012 1:47pm |
