Home > Faults & Fixes > Fuel door won't open at times on My 2005 RRS HSE !!!
Reidy4862
2005 Range Rover Sport TDV6 Zermatt Silver
Please Help
As I have stated in My title, at times I push the door in on petrol door and it won't open likes its still locked. I push it in a few times and press the Lock/Unlock on the Central Locking several times and eventually it opens, had this several times
Please Help
Post #363462 Sat Nov 17 2012 5:15pm
jitzz
Hi Reidy,
I had the same problem on mine (55 S/C). I had to use a credit card to flick it open...which didn't look cool at the petrol station Embarassed it turned out to be the small plastic parts which form the catch mechanism.
I ordered the 3 small pieces from Dan at Duckworth parts, only cost a few quid Very Happy
I replaced these and sprayed a little WD40 for the springy thing and all is good !
Hope that helps
Jitzz
Post #369623 Wed Jan 16 2013 4:33pm
joeand
England 2006 Range Rover Sport Supercharged Zambezi Silver
I'm having the same problem do you no the part numbers Thumbs Up
Post #369826 Thu Jan 17 2013 8:18pm
jitzz
Hio Joeand,
Yes I do...still got the bags they came in, I'll get them for you tonight when I get home - they are in the garage !!?
Thanks
Jitzz
Post #369918 Fri Jan 18 2013 10:43am
jitzz
Hi Joeand,
here are the part numbers that you asked for, there are three parts which I ordered from Duckworths,
It doesn't clearly state 'part number' so I've given you the ones which I think are relevant.
Actuator : BPA780101 or TO number 2090794088, stock number 61277
Latch : BPA780110 or TO number 2090794088, stock number 61277
Bezel : ARV780020 or TO number 2090794084, stock number 60760
Hope this helps ...give me a shout if you need anything else !
Thanks
Jitzz
Post #370096 Sat Jan 19 2013 12:51pm
mse
The first numbers are the part number Mike
2014 Facelift Discovery
Post #370107 Sat Jan 19 2013 2:28pm
joeand
Is it an easy install
Post #370153 Sat Jan 19 2013 7:29pm
jitzz
Yes very easy install.... The only bit of kit you will need is a small blade screwdriver to get the latch in place, all the other bits just clip into place
Post #370170 Sat Jan 19 2013 9:40pm
patxi
Spain 2005 Range Rover Sport TDV6 SE Java Black
Just ordered the same 3 parts from Dan at Duckworths - great stuff and less than a fiver. They also ship to Spain which I'm very pleased about. Hope I don't screw up the fitting Shocked
Post #402849 Tue Nov 19 2013 8:45pm
