Home > Faults & Fixes > Fuel door won't open at times on My 2005 RRS HSE !!! |
jitzz Member Since: 10 Dec 2012 Location: Loughborough Posts: 26 |
Hi Reidy,
Wed Jan 16 2013 3:33pm |
joeand Member Since: 22 Aug 2012 Location: manchester Posts: 104 |
I'm having the same problem do you no the part numbers |
Thu Jan 17 2013 7:18pm |
Hio Joeand,
Fri Jan 18 2013 9:43am |
Hi Joeand,
Sat Jan 19 2013 11:51am |
The first numbers are the part number Mike
Sat Jan 19 2013 1:28pm |
Is it an easy install |
Sat Jan 19 2013 6:29pm |
Yes very easy install.... The only bit of kit you will need is a small blade screwdriver to get the latch in place, all the other bits just clip into place |
Sat Jan 19 2013 8:40pm |
patxi Member Since: 14 Nov 2013 Location: Bilbao Posts: 7 |
Just ordered the same 3 parts from Dan at Duckworths - great stuff and less than a fiver. They also ship to Spain which I'm very pleased about. Hope I don't screw up the fitting |
Tue Nov 19 2013 7:45pm |
