Home > Faults & Fixes > cargo trunk cover too short
Evaldaslk
Lithuania 2007 Range Rover Sport 4.4 V8 HSE Java Black
I have this continuous problem. It seem that cargo trunk cover is too short for the distance between the fixation places. I draws attention of course only when putting thing into the trunk.
The view is that one side hangs lower only because the gripping mechanism catches the rim of the interior. Dealer measured trunk cover from another car and it seem that the problem is in the space of the interior but I have no ideas how coud the interior parts shift so much for the cover to become too short.
If anyone have some ideas about fixing this problem please let me know
Post #360859 Thu Oct 25 2012 11:49am
Welcome Smile
A picture showing the problem might help someone offer a solution Thumbs Up
It 'should' be a simple fit of the cover and pull it out to the desired fixing point (I believe there are two. It soulds like your cover/mechanism has taken a knock and is compressed. Again a picture should help. Smile ON THE WAY: BMW F21 M140i
Post #360860 Thu Oct 25 2012 12:00pm
Evaldaslk
ill download a picture as soon as possible.
Post #360861 Thu Oct 25 2012 12:02pm
simple1
Had this with mine and dog guard was blamed by stealer. In the end they replaced the side panels and packed them with foam between the cover and inner wing. LR technical say it is a reaction to heat and cold and the panels eventually shrink. Even with the foam the same is happening again and won't be too long before the load cover starts falling into the boot again. Design issue that is not the load cover but the mounting points. Great for a 60 grand car!! 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #362328 Thu Nov 08 2012 10:50am
mjbrr
United Kingdom 2009 Range Rover Sport TDV8 HSE Santorini Black
I had the same problem with mine.
Shoved a couple of erasers in one side.... Sorted
Very Happy 2009 3.6 TDV8 HSE Santorini Black
Post #362345 Thu Nov 08 2012 12:46pm
