Home > Faults & Fixes > cargo trunk cover too short |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Welcome
Thu Oct 25 2012 11:00am |
Evaldaslk Member Since: 25 Oct 2012 Location: Lithuania Posts: 2 |
ill download a picture as soon as possible. |
Thu Oct 25 2012 11:02am |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Had this with mine and dog guard was blamed by stealer. In the end they replaced the side panels and packed them with foam between the cover and inner wing. LR technical say it is a reaction to heat and cold and the panels eventually shrink. Even with the foam the same is happening again and won't be too long before the load cover starts falling into the boot again. Design issue that is not the load cover but the mounting points. Great for a 60 grand car!! 2x TDV6. SE and HSE. Both returned to sender with issues👀
Thu Nov 08 2012 9:50am |
mjbrr Member Since: 31 May 2012 Location: Durham Posts: 81 |
I had the same problem with mine.
Thu Nov 08 2012 11:46am |
