Home > Faults & Fixes > Front direction light, dash warning light
cubbyno9
Hi everyone,
I have a 2006 RRS S/C and have on issue with the bulb warning light on the dash, it is flashing saying there is an issue with side directional lamps. I have my lights set to auto, and when I turn the corner slow they certainly seem to be coming on and working OK. I have replaced both bulbs and again it appears to be working but the dash light is still blinking at me. I have lived with it for a while now but it is beginning to annoy me !!!!
Thanks in advance.
Craig 2017 Range Rover Sport HSE
Post #359110 Tue Oct 09 2012 1:41pm
Have you replaced the bulb with a genuine/high quality one? I've heard about LR's being particularly fussy in that regard.
Failing that, could be a wiring issue Confused ON THE WAY: BMW F21 M140i
Post #359113 Tue Oct 09 2012 2:01pm
cubbyno9
Hi Beancounter,
The bulbs were from Halfords, should I get them from the Land Rover garage, do you think it could be as simple as that.
I will try this and if still the same then try an auto electrician, thanks.
craig 2017 Range Rover Sport HSE
Post #359114 Tue Oct 09 2012 2:08pm
kav1187
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Hi Craig,
Judging from what I've read on other posts, it could well be the halfords bulb that's causing it. This has definately been an issue with the brake light bulbs which have caused some big problems for some people so I'd imagine it could be the same for your direction light bulbs also.
Try getting the bulb from LR and if it doesn't fix the issue then we'll see if we can come up with more ideas Very Happy
Kav
Post #359708 Mon Oct 15 2012 11:42am
mrfrog
United Kingdom 2005 Range Rover Sport Supercharged Vesuvius Orange
I'm running Bosch bulbs bought from halfords and not having any issues. On my P38 however, the halford's own bulbs kept blowing and causing warning messages, swapped for Bosch items, problem gone.
"Roads ? Where we're going there are no roads." Back to the future.
Post #359782 Mon Oct 15 2012 5:33pm
