Home > Technical > Brake Pedal making a Knocking noise on the Gear Stick.
Reidy4862
2005 Range Rover Sport TDV6 Zermatt Silver
You will be a good one if you can help me with this one......
This Evening I have noticed that as soon I turn my Key in the Ignition so either all the dash lights come on OR I actually turn the engine on, if I tap my foot on the Brake Pedal in either P (Park) or N (Natural) a knocking noise appears from the Gear stick Area and if I have my Hand on the Gear Stick I can Actually Feel it. If I have the Car in D (Drive) or R (Reverse) or have the Key out the Ignition altogether then it doesn't make the knocking Noise.
Anyone know what this is? And does it do it on Your RRS? Also it wouldn't have anything to do with My Low Battery Power would it? (Posted in a Different Thread)
Please Help as its Very Worrying
Post #357184 Wed Sep 19 2012 10:43pm
CUCO
Spain
dont worry.
it's the blockage pin solenoid that inhibits the gear stick movement from P or N if the brake pedal is not pressed.
a security feature.
Post #357185 Wed Sep 19 2012 10:52pm
Reidy4862
CUCO wrote:
dont worry.
a security feature.
so Is it normal then as I have only just noticed that it does this? It does sound quite loud and you really can feel it on the gear stick. Also as I have said in D Drive or R Reverse it doesn't make a noise at all its just N Netural and R Reverse. Also coz it is placed in Park when you stop the next time to put your key in the ignition until the dash lights appear you can hear the click.
Plz reply
Post #357187 Wed Sep 19 2012 11:00pm
CUCO
Spain
100% OK
P is a "TOTAL STOP" position
N is a "TEMP STOP" position
all the others "RUN" position and because of this, they must not be blocked so no need to lock them
imagine that a child moves the stick out of the P or N, from the rear seat when you are out of the car Arrow movement and Arrow ...accident or damage for sure...
with the brake pedal press needed, this fact is so less easy to happen.
i feel the "clack" every time i press the brake pedal but...maybe i'm so mechanical or acustical sensitive...
Post #357188 Wed Sep 19 2012 11:06pm
CUCO
Spain
if you hear and feel a very loud "knock" as is the stick is soo heavily hammered them something is not good there...but hear and feel a slight "clack" every time you have the brake pedal pressed AND the stick is in P or N is 100% OK
Post #357189 Wed Sep 19 2012 11:14pm
Reidy4862
[quote="CUCO"]if you hear and feel a very loud "knock" as is the stick is soo heavily hammered them something is not good there...but hear and feel a slight "clack" every time you have the brake pedal pressed AND the stick is in P or N is 100% OK[/quote
Yeah I feel a slight knock under the Gear stick each and every time I tap the brake pedal in N and P and I can hear the knock noise from the gear area, just a bit worried as I hadn't noticed It before.
Post #357190 Wed Sep 19 2012 11:19pm
CUCO
Spain
dont worry, your car is safe and OK. Thumbs Up
enjoy it, they are wonderful cars! (when they are ok...so enjoy while they are!!!) Very Happy
Post #357192 Wed Sep 19 2012 11:22pm
CUCO
Spain
if you want to see what is the noise generator "thing", is the shift lock solenoid in this document.
we have the lock in P and N.
Disclaimer:
don't blame me please as the document is from Toyota...google magic...
toyota only locks P as in this document.
http://www.google.es/url?sa=t&rct=j&am...mp;cad=rja
Post #357193 Wed Sep 19 2012 11:32pm
Reidy4862
Does anyone else have this on there RRS ?????
Post #357223 Thu Sep 20 2012 9:19am
Bradders
Yeh - just like CUCO says. FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
EX 2007 FL2 XS - not so bad
Post #357229 Thu Sep 20 2012 9:50am
Reidy4862
Ok cheers, just sounds bad though as it clicks when you push the brake pedal in and then clicks again when you release the pedal !!!!
Post #357261 Thu Sep 20 2012 11:48am
Bobby
The noise/feel is caused by the Shift Interlock Solenoid.
The shift interlock solenoid is located on the side of the selector lever assembly. The solenoid operates two locking levers which engage in the lower lever and lock it in the Park (P) and Neutral (N) positions.
When the ignition is on or the engine is running, the solenoid is de-energised and prevents the lever from moving. When energised, by the depression of the footbrake, the solenoid is energised and the selector lever may be moved from the P position.
If the selector lever is left in the N position for more than 800m/s the solenoid will be energised and the selector lever will become locked in the N position. To move the selector lever from the N position in this condition the footbrake must be applied. This prevents the selector lever from being moved to the 'D' or 'R' position unintentionally and the application of the brakes also prevents the vehicle 'creeping' when the gear is engaged.
So, what you're hearing/feeling is the locking levers engaging/disengaging!
Don't worry! Wink Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #357266 Thu Sep 20 2012 12:26pm
Reidy4862
Don't worry! Wink
Thanks for the great write up, it's putting mind at rest now
Cheers everyone for your help
Post #357274 Thu Sep 20 2012 1:34pm
flydive
To Bobby's write up, I would add that if stopped in N on a slight incline holding the brake pedal the solenoid will be energized.
As you remove the foot the solenoid will become de-energized but as the car start to move few feet the solenoid will be energized again al the lever will move freely(do not know if based on speed, distance or time) '08 RRS TDV8
Post #357278 Thu Sep 20 2012 1:46pm
Lateral5
Australia
Yep, I kind of like it....press the brake and bingo a click in the gearstick. Sometimes I just sit there and do it a dozen times....because I can! RRS TDV6 Bluetooth, VR, Roof
Post #357941 Wed Sep 26 2012 12:52pm
