![]() | Home > Technical > Brake Pedal making a Knocking noise on the Gear Stick. |
CUCO Member Since: 02 Jun 2011 Location: Spain & Oleee!!! Posts: 59 ![]() ![]() |
dont worry.
Reidy4862 Member Since: 29 Feb 2012 Location: Middlesbrough Posts: 48 ![]() ![]() |
so Is it normal then as I have only just noticed that it does this? It does sound quite loud and you really can feel it on the gear stick. Also as I have said in D Drive or R Reverse it doesn't make a noise at all its just N Netural and R Reverse. Also coz it is placed in Park when you stop the next time to put your key in the ignition until the dash lights appear you can hear the click. Plz reply |
100% OK
if you hear and feel a very loud "knock" as is the stick is soo heavily hammered them something is not good there...but hear and feel a slight "clack" every time you have the brake pedal pressed AND the stick is in P or N is 100% OK |
[quote="CUCO"]if you hear and feel a very loud "knock" as is the stick is soo heavily hammered them something is not good there...but hear and feel a slight "clack" every time you have the brake pedal pressed AND the stick is in P or N is 100% OK[/quote
dont worry, your car is safe and OK. |
if you want to see what is the noise generator "thing", is the shift lock solenoid in this document.
Does anyone else have this on there RRS ????? |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
Yeh - just like CUCO says. FF 4.4 V8 Soooo looking forward to this bad boy
Ok cheers, just sounds bad though as it clicks when you push the brake pedal in and then clicks again when you release the pedal !!!! |
The noise/feel is caused by the Shift Interlock Solenoid.
Thanks for the great write up, it's putting mind at rest now Cheers everyone for your help |
flydive Member Since: 16 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
To Bobby's write up, I would add that if stopped in N on a slight incline holding the brake pedal the solenoid will be energized.
Lateral5 Member Since: 07 Jun 2006 Location: Down south Posts: 331 ![]() ![]() |
Yep, I kind of like it....press the brake and bingo a click in the gearstick. Sometimes I just sit there and do it a dozen times....because I can! RRS TDV6 Bluetooth, VR, Roof ![]() |
