Home > Maintenance & Modifications > Rear Aux connector a dummy?
b3nle
United Kingdom 2005 Range Rover Sport Supercharged Santorini Black
Hi Guys,
Finally got round to picking up a 3.5mm phono to phono lead so i can listen to my ipod through the aux input in my 2005 RRS S/C..... i go to plug in at the Aux point behind the centre console & it wont fit or push in enough? Sad
Any ideas or am i being completly stupid? Is it a dummy point? It clearly says aux above it.....I can't say plugging in a phono lead has ever stump me before!?
Post #354416 Wed Aug 22 2012 9:49am
Gary
Shouldn't be a dummy so check to see if there is anything wedged in there?
Post #354419 Wed Aug 22 2012 10:45am
Bodsy
Site Sponsor
it can happen that other people break them whilst in there. you should be able to pull the plastic out to get to the back of the plug and you may well find a bit of a phono plug or some other piece of childs toy in there! Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #354423 Wed Aug 22 2012 12:18pm
b3nle
thanks - i'll have a look later and report back!
Post #354428 Wed Aug 22 2012 1:50pm
Paddi
You are using a 3.5mm jack to 3.5 mm jack like this aren't you? http://www.amazon.co.uk/3-5mm-Stereo-Jack-Plug-1-2M/dp/B00077DC3S
Just checking because 'phono' plug is something else. Apologies if you already have the right cable. 2008 MY Java Black TDV8 HSE
Post #354446 Wed Aug 22 2012 4:25pm
Jimmy_75000
France 2010 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Hi Boday,
I have this problem at the moment.. The top tip of my able broke inside the plug... You seems Tom indicate that we should be able to remove the aux connector from the rear of the console... Any particular way to do that? Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #364172 Fri Nov 23 2012 7:44am
