Home > Maintenance & Modifications > Rear Aux connector a dummy? |
Gary Member Since: 22 Jun 2006 Location: Essex Posts: 268 |
Shouldn't be a dummy so check to see if there is anything wedged in there? |
Wed Aug 22 2012 10:45am |
it can happen that other people break them whilst in there. you should be able to pull the plastic out to get to the back of the plug and you may well find a bit of a phono plug or some other piece of childs toy in there! Bodsys Brake Bible
Wed Aug 22 2012 12:18pm |
b3nle Member Since: 24 Jul 2012 Location: nr bridgend Posts: 10 |
thanks - i'll have a look later and report back! |
Wed Aug 22 2012 1:50pm |
You are using a 3.5mm jack to 3.5 mm jack like this aren't you? http://www.amazon.co.uk/3-5mm-Stereo-Jack-Plug-1-2M/dp/B00077DC3S
Wed Aug 22 2012 4:25pm |
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 |
Hi Boday, I have this problem at the moment.. The top tip of my able broke inside the plug... You seems Tom indicate that we should be able to remove the aux connector from the rear of the console... Any particular way to do that? Range Rover Vogue ‘17 TDV6 Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56 |
Fri Nov 23 2012 7:44am |
