Home > Maintenance & Modifications > Park brake fault - please help
Worried
Scotland 2008 Range Rover Sport TDV8 HSE Izmir Blue
Hello gents
Sorry for the post if previously covered (I have not found it yet)
I picked up my Range rover sport late 2007 on Tuesday, gave it a good scrub and polish today
When I went to park it, I applied the park brake, it went with a few creaks and bang followed by park brake fault and Christmas tree lights on the dash
Something's broken
I know, prior to me picking up car the car was serviced by an independent, new brake pads front and rear fitted along with an MoT......
Am I correct to suggest that after fitting new brake pads the electronic handbrake has to be adjusted ?
Is the hand brake shoes inboard of the brake disc as an independent system ???
If the fault is present is the handbrake off and car safe to drive or is it a tow truck issue
I have been in touch with the supplying dealer, however advice would be appreciated and greatly received Sad Sad Sad Izmir Blue TDV8
Post #352705 Thu Aug 02 2012 5:34pm
Hugh Haddow
Scotland 2013 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Had something similar a couple of times on my 09 RRS.
If the EPB is stuck on it can be manually released using the hook device found in the tool kit by the jack. The difficulty is accessing the cable loop in the centre console. To get at it you need to pull off the gear knob. It’s not easy you need to be determined. Then the console top cover has to be eased off. In there you will find a wire loop. Catch it with the tool and give it a good hard pull. This will release it.
Sorry I don’t know how to fix it though.
Good luck.
Post #352714 Thu Aug 02 2012 8:30pm
Worried
Many thanks for reply Hugh
As it is the park brake is not applied.
From reading threads via google on different forums, they read as if it's a problem with the Electronic Park brake actuator ????
Didn't think the car would be back in the garage so soon ......... Big Cry
I shall try and get it booked in tomorrow..... Izmir Blue TDV8
Post #352717 Thu Aug 02 2012 9:12pm
jaguar1
Saudi Arabia 2007 Range Rover Sport TDV8 HSE Stornoway Grey
@ Worried, I have a similar problem with my 57 plate RRs tdv8. No screeching noises but the EPB warning light comes on intermitently. Let us know how you get on with yours.
John
Post #352830 Sat Aug 04 2012 7:52am
scrumps
Hi,
I have an EPB fault comes up on my 10MY TDV8. I've checked the EPB works manually, on and off - all OK. I've used hill asssist - all OK , I've tried the "Emergency function" - all OK. Have noticed it only comes up when the car has been parked for a "period" (6-8hrs +). Have now found out (phone call to friendly dealer) that it can be caused by low battery voltage when cranking the engine over. Confirmed this by using diagnostic mode on the centre screen (code 753) and found the voltage drops to 10.7 volts after an overnight stand or after work. Car is going into Main Stealers on Tuesday morning for a new battery - hopefully that will sort it.
I know this won't help someone with a duff actuator - but it might help some others.
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #352848 Sat Aug 04 2012 2:36pm
cliftonvilla
Great reply thanks for the info. Thumbs Up 2010MY Overfinch
Post #352900 Sun Aug 05 2012 7:57am
cliftonvilla
Post #352901 Sun Aug 05 2012 7:58am
cliftonvilla
Post #352902 Sun Aug 05 2012 8:01am
Worried
Update
Car is booked in on 17th for warranty repair
I believe the diagnosis starts with a rear brake strip down, calipers and disc removed, to see whats what
when the Parking brake is applied, the actuator can be heard working ???
Though light and fault appear on the dash.
I think it's actuator related, shall wait for the bill and better advise ...........
Big Cry Big Cry Big Cry Izmir Blue TDV8
Post #353434 Sat Aug 11 2012 2:12pm
