Home > Faults & Fixes > Suspension Fault - Normal Height Only
jaggy
United Kingdom 2006 Range Rover Sport TDV6 HSE Stornoway Grey
So intermittently, for no apparent reason I get *dong* Suspension Fault - Normal Height Only.
56 Plate 2.7 TDV6
Any suggestions...
Thanks
Post #351426 Sun Jul 22 2012 9:57am
Check that the battery is ok.
Could be that the compressor is getting tired. Or that the relay controlling it is on its way out. 2012 SDV6 - it's missing a couple of cylinders
Post #351428 Sun Jul 22 2012 11:07am
mrfixit
2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Battery is a good call but if your getting no other problems,most likely a sensor.check the orange blocks on the axle on the 4x4 screen.One only needs to be a fraction out and it can cause this.
The wires on the sensors are very exposed and can give a bad signal.You can get to them easily and check them and a squirt of wd40 helps.
Steve
Post #351470 Sun Jul 22 2012 8:00pm
panpicker
I have the same problem !! Drives you mad as I was told alternator £495 later still the same so changed battery and still the same ? Big Cry
Post #351601 Mon Jul 23 2012 6:36pm
shepp
hello
your issue may be an internal leak on your compressor, caused by a weak exhaust valve. My rrs started by intermittantly flashing up amber with the suspension fault. I fixed mine 3 1/2 months ago and not had any issues. Its also is worth checking the wiring in the front wheel arch.
Just requires a few upgrades to the compressor, also it would be worth drying out the air dryer at the same time. The TSB below explains how to upgrade the compressor.
http://www.rrsport.co.uk/gallery/albums/us...rogram.pdf
It is a fairly easy job if you have some decent tools and a small two arm gear puller (use it to remove and replace the exhaust valve cap)
The below is the repair kit, can also be purchased from the dealers
http://www.brit-car.co.uk/product.php?xProd=139015
this is a quick guide from the disco 3 site on how to remove the compressor
http://www.disco3.co.uk/forum/topic67721.h...eplacement
use pleanty of penetrating oil on all connectors befor removal
Post #351609 Mon Jul 23 2012 7:38pm
