![]() | Home > Faults & Fixes > Suspension Fault - Normal Height Only |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9050 ![]() ![]() ![]() |
Check that the battery is ok.
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 ![]() ![]() |
Battery is a good call but if your getting no other problems,most likely a sensor.check the orange blocks on the axle on the 4x4 screen.One only needs to be a fraction out and it can cause this.
panpicker Member Since: 27 Dec 2009 Location: buckingham Posts: 38 ![]() ![]() ![]() |
I have the same problem !! Drives you mad as I was told alternator £495 later still the same so changed battery and still the same ? |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
hello
