Home > In Car Electronics > How do you use the air con?
farazk
I know it's a pretty stupid question but I tried using it today, hen I press the econ button the air coming out of the vents is not chilled when I just have the temp setting at minimum (blue dot) the air is colder but still does not feel like air con. Any advice?
Post #351137 Thu Jul 19 2012 4:10pm
eco button disables cooling Thumbs Up
so the coolest air you're gunna get through the vents is outside temp RRS gone
Post #351139 Thu Jul 19 2012 4:12pm
farazk
So to activate the ac the temp dial should be on the blue spot?
Post #351142 Thu Jul 19 2012 4:15pm
not 100% correct nor 100% incorrect Mr. Green
The system is climate control not "air con"
Therefore you set the internal temp of the car (in both zones) and the car decides if it needs to use the air conditioning compressor to artificially cool the air or not.
if you set your temp to 20 degs and it's 21 outside, you'll get a little bit of cooled air...if you change it to 16 then yes it'll blast ice cold air till you get to 16 degs in the car Thumbs Up RRS gone
Post #351148 Thu Jul 19 2012 4:24pm
If you want to save the planet (and why would you driving a RRS) then you could select the econ button, which isolates the air con function totally... giving better mpg, lower emissions and a hot stuffy driver Laughing RRS gone
Post #351150 Thu Jul 19 2012 4:26pm
fkarim
Don't know if it's the same for MY10 onwards but on 05-09 when the "Eco" mode is off your air con is working. It will then cool the air according to your temp settings on the dials.
Post #351151 Thu Jul 19 2012 4:28pm
farazk
Ok makes sense. Thanks for all the info guys. I think my car might just need a regas.
Post #351154 Thu Jul 19 2012 4:45pm
farazk
I was just a bit confused as this is my first car without a specific air con button.
Post #351155 Thu Jul 19 2012 4:46pm
MAW
Laughing
Post #351156 Thu Jul 19 2012 4:47pm
ChrisP
Also bear in mind it also dehumidifies which keeps all the electronics dry. MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Audi A5 Sportback Black Edition 3.0 tdi quattro S Line
Post #351160 Thu Jul 19 2012 5:00pm
DaveM
2009 Range Rover Sport TDV6 HSE Stornoway Grey
RT Censored Censored Censored M. Banging Head
Post #351164 Thu Jul 19 2012 6:05pm
simonj007
England 2007 Range Rover Sport Supercharged Zermatt Silver
Hi,
Just re-visiting this point...
So when I turn both temp dials to the lowest setting i.e the blue dot - should that automatically kick in the fan blowers?
Especially like today when the outside temp is 24C...
My fans don't automatically kick in and the air blowing is not icy cold?
Any thoughts?
Thanks,
Simon
Post #427057 Fri Jun 13 2014 9:14am
Guyzer73
Not sure about the "ice cold blast"... Living in the middle east the Sport's climate control barely copes. It currently 40c outside and the system takes an age to get to 25c.
System has been checked regassed etc but no change...
Regards
Post #427064 Fri Jun 13 2014 9:58am
simonj007
Thanks Guy,
Quick one - do you know if my headlamps need adjusting for driving on the right - its a 2007?
If so, how?
Regards,
Simon
Post #427066 Fri Jun 13 2014 10:08am
