![]() | Home > In Car Electronics > How do you use the air con? |
eco button disables cooling |
farazk Member Since: 04 May 2012 Location: London Posts: 41 ![]() ![]() ![]() |
So to activate the ac the temp dial should be on the blue spot? |
not 100% correct nor 100% incorrect |
If you want to save the planet (and why would you driving a RRS) then you could select the econ button, which isolates the air con function totally... giving better mpg, lower emissions and a hot stuffy driver |
Don't know if it's the same for MY10 onwards but on 05-09 when the "Eco" mode is off your air con is working. It will then cool the air according to your temp settings on the dials. |
Ok makes sense. Thanks for all the info guys. I think my car might just need a regas. |
I was just a bit confused as this is my first car without a specific air con button. |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
ChrisP Member Since: 26 Jan 2008 Location: Derbyshire Dales Posts: 1392 ![]() ![]() ![]() |
Also bear in mind it also dehumidifies which keeps all the electronics dry. MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
DaveM Member Since: 23 Jul 2009 Location: United Kingdom Posts: 40 ![]() ![]() |
RT |
simonj007 Member Since: 11 Sep 2013 Location: Buckinghamshire Posts: 148 ![]() ![]() ![]() |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
Not sure about the "ice cold blast"... Living in the middle east the Sport's climate control barely copes. It currently 40c outside and the system takes an age to get to 25c. System has been checked regassed etc but no change... Regards Guy 2006 RRS S/C CONSTANTLY under modification... 1994 RRC 4.2l not LSE sadly gone but not forgotten LR Defender 300Tdi - affectionately know as "The Black Beast" |
Thanks Guy,
