You are currently viewing RRSPORT.CO.UK as a guest - Register to take part or Log In
Home > Technical > Range Rover SS Dynamic Response Problem
Adrian Busuttil
Hi. After I took my Range Rover SS out while driving a Dynamic Response warning light (RED) came on. A short beep was also heard and the warning light constantly on. In the message center the following is being shown: SUSPENSION FAULT STOP SAFELY STOP ENGINE.
Vehicle is working fine and the suspension is all Level with the road. When Suspension is selected to Lower & Higher modes, everything works well even whilst driving, no problems whatsoever are being noticed by me.
Can you give me an idea of what could be wrong and how I could solve this issue ?
Regards,
Adrian Busuttil
Fri Jul 13 2012 2:24pm
s335
could be a leaky roll bar, possibly a fault with the ace system, maybe a filter or a valve body on it, only way you will find it is with a code read
