Home > Technical > Range Rover SS Dynamic Response Problem
Adrian Busuttil
Hi. After I took my Range Rover SS out while driving a Dynamic Response warning light (RED) came on. A short beep was also heard and the warning light constantly on. In the message center the following is being shown: SUSPENSION FAULT STOP SAFELY STOP ENGINE.
Vehicle is working fine and the suspension is all Level with the road. When Suspension is selected to Lower & Higher modes, everything works well even whilst driving, no problems whatsoever are being noticed by me.
Can you give me an idea of what could be wrong and how I could solve this issue ?
Regards,
Adrian Busuttil
Fri Jul 13 2012 3:24pm
s335
could be a leaky roll bar, possibly a fault with the ace system, maybe a filter or a valve body on it, only way you will find it is with a code read
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
