Home > Wheels & Tyres > Strange feathering on front tyres
Both front tyres have just started to exhibit feathering of the shoulder blocks on both the inside and outside shoulders. Feathering is the same on each shoulder. The feathering is such that it's smooth rubbing the tyre front to rear at the top but jagged rubbing it rear to front at the top (if that makes sense)
Feathering is usually a sign of a toe in/out issue and one would expect either the inner or outer shoulders to be feathered depending on whether total toe is in or out. As all four shoulders are showing signs, this suggests that the suspension is doing odd things.
The rear dynamic response ARB is to be replaced next week as it's leaking and I'm hoping that this is the cause of the strange wear pattern. However, the NSF ARB bush was replaced a few weeks ago and I wonder if the bolts might be loose causing some suspension wander at the front.
Anyone got any thoughts? Tempted to get the geometry looked at but it seems daft to spend money on that and then have the suspension played with a few days later. Will have it checked afterward unless the LR dealer confirms it's been checked and is in spec.
I'm hoping the new rear ARB will sort it as the shoulders are getting eaten quite hard at the front. The rears are showing uniform wear and look as good as new. I could do without trashing a pair of tyres at the moment... 2012 SDV6 - it's missing a couple of cylinders
Post #350492 Thu Jul 12 2012 1:00am
Bradders
Silly question I know but have you checked tyre pressures - I guess under inflating could lead to both outer edges wearing ?????? FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
EX 2007 FL2 XS - not so bad
Post #350499 Thu Jul 12 2012 10:33am
Sounds like it needs a 4 wheel alignment again.
What type of tyre is it? RRS gone
Post #350501 Thu Jul 12 2012 11:53am
Pressures are ok but will monitor them more often to be sure
Tyres are 255/55/19 Scorpion ATR
I'm hoping that the new rear ARB unit will be the answer but an alignment check is likely to be necessary too just to be sure. Will also get the garage to check the front ARB again when they're doing the rear one - just to be sure.
I'm wondering if the rear ARB failing is making the car understeer a bit more which is why the shoulders are getting worn. That's my current hypothesis anyway. 2012 SDV6 - it's missing a couple of cylinders
Post #350503 Thu Jul 12 2012 12:00pm
could be putting more load on the tyre shoulders yes..
Might also be the fact they are an ATR and thus not 100% tarmac resistant with the warmer (laughs) summer months? RRS gone
Post #350504 Thu Jul 12 2012 12:05pm
AJS4X4
Swap front to rear will help with wear but it does sound like you need 4 wheel alignment. Please call us 01737 241370 for the quickest response Smile
www.ajstyres.co.uk
Post #350508 Thu Jul 12 2012 12:42pm
It's going in for the ARB work on Thursday next week so hopefully I can keep the mileage down until then. Once that is done I can get the alignment checked.
I put 2psi in the front tyres this lunchtime in the hope that this will help support the shoulders. 2012 SDV6 - it's missing a couple of cylinders
Post #350512 Thu Jul 12 2012 3:00pm
Spoke to a LR indie (James French near Oxford) who do 4-wheel alignment. They advised that I may as well wait until the ARB is done because, usually, bits of suspension need to be removed to change it. Thus it will need to be aligned after the work anyway.
Was impressed that he didn't just take my £60. I guess some places might have even knowng that I would be undoing it all in a few days anyway. So a Thumbs Up for James French there.
Will check that the LR garage does a full alignment check/adjustment as part of their work. Also, I think I'll get them to confirm that new bushes are installed with the new ARB (I wouldn't put it past a garage to reuse the old ones...). Might get them to check the bolts for tightness on the front ARB bush they that they replaced a month ago. Might see if I can get them to cha nge the other front one too. That way it'll be new ARB bushes alround.
I think I'm going to park the RRS until Thursday and then just take it in and leave it with them. Better than trashing the front tyres, even if it means sharing the other car with SWMBO for a few days.
It's a good job I like driving the RRS - I've had cars that were better built in the past. And one of those was a Suzuki! 2012 SDV6 - it's missing a couple of cylinders
Post #350588 Fri Jul 13 2012 4:24pm
SONYBOY
United Kingdom 2007 Range Rover Sport TDV6 HSE Zermatt Silver
front wear
Hmmmm,think mine are doing the same,my fronts are starting to wear on the inside only on both fronts, whats the correct pressure for 275/40 R20 106Y continentals, and pressure for the Rears please Confused 2007 COOLRRS
Post #353424 Sat Aug 11 2012 1:29am
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
Re: front wear
36 all round for me.
Post #353449 Sat Aug 11 2012 9:34pm
