![]() | Home > Wheels & Tyres > Strange feathering on front tyres |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
Silly question I know but have you checked tyre pressures - I guess under inflating could lead to both outer edges wearing ?????? FF 4.4 V8 Soooo looking forward to this bad boy
Sounds like it needs a 4 wheel alignment again.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9048 ![]() ![]() ![]() |
Pressures are ok but will monitor them more often to be sure
could be putting more load on the tyre shoulders yes..
AJS4X4 Member Since: 28 May 2008 Location: Surrey Posts: 286 ![]() ![]() |
Swap front to rear will help with wear but it does sound like you need 4 wheel alignment. Please call us 01737 241370 for the quickest response |
It's going in for the ARB work on Thursday next week so hopefully I can keep the mileage down until then. Once that is done I can get the alignment checked.
Spoke to a LR indie (James French near Oxford) who do 4-wheel alignment. They advised that I may as well wait until the ARB is done because, usually, bits of suspension need to be removed to change it. Thus it will need to be aligned after the work anyway.
SONYBOY Member Since: 22 Dec 2010 Location: East Of England Posts: 70 ![]() ![]() ![]() |
Hmmmm,think mine are doing the same,my fronts are starting to wear on the inside only on both fronts, whats the correct pressure for 275/40 R20 106Y continentals, and pressure for the Rears please |
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 ![]() ![]() ![]() |
36 all round for me. |
