Home > Technical > 2010 3.0 tdv6 rrs fuel filter bleeding
merlin1
2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
hi has anyone a pdf for fuel filter fitting and bleeding procedure thanks .
Post #350400 Wed Jul 11 2012 12:49pm
This discussed the other day with a solution provided by Bobby
Have you tried a search? RRS gone
Post #350406 Wed Jul 11 2012 1:28pm
http://www.rrsport.co.uk/gallery/albums/us...eeding.pdf
http://www.rrsport.co.uk/forum/post349602.html#349602
Post #350409 Wed Jul 11 2012 1:55pm
merlin1
Fuel
Cheers for that but that was a 3.6 v8?
Post #350488 Wed Jul 11 2012 10:53pm
merlin1
so is it the same as 3.6 v8 then ?
Post #352471 Tue Jul 31 2012 4:47pm
mse
Every time ive changed a fuel filter - including on a D3 - ive never bled it - remove the old - top the new one up insert, start let run for a few minutes and it will self bleed.
The trick is to not fit one empty. Mike
2014 Facelift Discovery
Post #352475 Tue Jul 31 2012 5:07pm
s335
you have to change the filter and leaave the ignition on for a few miutes that will be bleeding forr it, if you start it and it cuts out there is a valve by oil filter put cap into it with ignition on and it will bleed it
Post #352907 Sun Aug 05 2012 11:21am
merlin1
Post #353229 Wed Aug 08 2012 10:46pm
merlin1
Post #353230 Wed Aug 08 2012 10:46pm
