Home > Technical > 2010 3.0 tdv6 rrs fuel filter bleeding |
This discussed the other day with a solution provided by Bobby
Wed Jul 11 2012 12:28pm |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 |
http://www.rrsport.co.uk/gallery/albums/us...eeding.pdf
Wed Jul 11 2012 12:55pm |
merlin1 Member Since: 16 Sep 2009 Location: cornwall Posts: 110 |
Cheers for that but that was a 3.6 v8? |
Wed Jul 11 2012 9:53pm |
so is it the same as 3.6 v8 then ? |
Tue Jul 31 2012 3:47pm |
Every time ive changed a fuel filter - including on a D3 - ive never bled it - remove the old - top the new one up insert, start let run for a few minutes and it will self bleed.
Tue Jul 31 2012 4:07pm |
s335 Member Since: 05 Aug 2012 Location: essex Posts: 12 |
you have to change the filter and leaave the ignition on for a few miutes that will be bleeding forr it, if you start it and it cuts out there is a valve by oil filter put cap into it with ignition on and it will bleed it |
Sun Aug 05 2012 10:21am |
Cheers |
Wed Aug 08 2012 9:46pm |
Cheers |
